Question about Dryers
Kenmore gas dryer 11072202100 burner lights then goes out after few seconds
  • Dryers Master
  • 43,501 Answers
If you have a gas dryerkenmore gas dryer 11072202100 burner lights then - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 28, 2010
Kenmore elite gas dryer model:110.70982990. Burner will ignite and burn for about 5-10 seconds then goes out. If started again, dryer does the same thing.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 30, 2011 | Kenmore 63942 Dryer
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
hi - i've run into identical problem with same dryer. did you find a solution? the drum spins, the gas does light up, but not for long enough to be of any use....
Sep 21, 2010 | Kenmore 63942 Dryer
Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Sep 03, 2009 | Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Kenmore natural gas dryer model#110.6917721. Igniter comes on and burner comes on for about a minute and goes out. Burner will come back on in a few minutes and then go out. It will do this severalm times...
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Jun 03, 2009 | Dryers
On my 4 year old Kenmore elite dryer the ignitor glows and
HI, Check your 4" vent to the outside and make sure it is clean and that it has no kinks.
Any restriction to the outside will cause the dryer to short cycle. All thermostats must have continuity. With the dryer running, remove the lint screen and check to see if there is good air flow by putting your hand in where the filter goes (it is safe). You should feel air rushing past your hand if the vent is clear.
I hope this helps you. Please let me know if I can assist you further.
Vic
Apr 14, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will turn and start heating then goes out...it's gas
Coil valves need to be replaced.they are the 2 black rounded on top of module where gas line goes into.aout 35 bucks for both.
Mar 28, 2009 | Kenmore 74602 Gas Dryer
Kenmore gas dryer wont ignite
your good,,i like that the coils...light up go out the ignitor..defective gas vavle coils..
Dec 30, 2008 | Kenmore 63942 Dryer
Dryers Logo
96 people viewed this question
Top Dryers Experts
