Question about RoadPro RPPI-2500W Inverter
My inverter is Roadpro 1500 but cannot power 700W microwave
It only works 5 or 6 six seconds and black out, would u please tell me how to solve it.
How good is the connection to the battery? there are a lot of amps that have to flow fast and clamps just don't do it, lugged cables do!
Posted on Apr 28, 2010
Connected a microwave (700 watt) and fault light turns on after few seconds on
engine has to be running with some high wattage items if your engine was running then your inverter is defective.
Mar 31, 2011 | RoadPro RPPI-2500W Inverter
My 24v 1500w inverter cuts out when i use my 700w microwave?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The starts up power for some appliances we use at home are sometimes higher than their actual power. For example a fridge will start with a power of 2 to 3kva then after start up it goes down to its normal power of 700va to 1kva .
Your inverter will continue to switch off if your if you battery is
  1. Low i.e. it is not fully charged
  2. Has a low ampere rating
The solution is to get a battery with a higher ampere rating like 200ampere/hour and above, connect it in parallel to the other battery i.e. the positive terminal to the positive terminal, the negative terminal to the negative terminal. This additional will accommodate the excess power needed for the microwave to start up.
Note that it is not advisable, to use this type of power appliance on a small inverter .Use a battery with the same volt rating i.e. a if you use a 24volts battery get another 24volts battery with a higher ampere rating
Apr 30, 2010 | RoadPro RPPI-2500W Inverter
Have several non working inverters
I have had this happen a few times.
Sadly replacement is the Best option.
Repairs can be %75 the cost of a new one.
The best invert we have been using is a Pure Sine 1500 watt inverter.
Sad news but hope this tip helps.
R/
David
Jan 09, 2010 | RoadPro RPPI-2500W Inverter
I have a roadpro 1500 what size wattage of
depends on the type of oven but usually a comfortable load is 3/4 the size of inverter out put
Sep 19, 2009 | Electronics - Others
Trying to find out what gauge of wire i need for a 1500 watt roadpro inverter to wire to batteries of a semi
At 12 volts DC it will pull 125 amps at full load of 1500 Watts.This requires at least #2 copper AWG
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 15, 2009 | RoadPro Electronics - Others
Can't get power to my RoadPro 1500 DC to AC Power Inverter
I have had this same problem with several power inverters over time. The problem is usually one of three things.
Those starting with the simplest.
1. Too much current being drawn on the inverter.
Solution (Check appliances that are plugged in and make sure they are not drawing more than 1200 watts. If they are unplug the appliance that is using the most current and get an inverter that is more suited to your power needs.)
2. Some power inverters have fuses built on to them. Sometimes multiple fuses. Sometimes, one fuse may burn out leaving one intact. When this happens even small items draw too much current and over load the inverter.
Solution (Replace the fuses)
3. Improper installation. Inverters draw a lot of current. You must use the propper wire size for the inverter. I would recomend at least an eight guage wire directly fused and hooked directly to the battery. Of course like with all things the bigger the wire the better the flow of electricity.
If it is not one of those things stop into a truck stop electronics shop and have the person diagnose it.
Hope that helps.
Jan 20, 2009 | RoadPro AC/DC Power Inverter 2000/5000w
RoadPro RPPI-2500W Inverter Logo
201 people viewed this question
Top RoadPro Electronics - Others Experts
Craig Butler
Craig Butler
jdthefixer
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
