Question about Brother IntelliFax-2820 Laser Fax
How do I let the machine know that I have replace the drum
    President:
  • 405 Answers
You need to open the front cover (where drum and toner is installed) and press the options button, it will ask replace drum? Press 1 for yes and close the front cover.
Posted on Apr 26, 2010
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
CLEAR DRUM UNIT COUNTER IN BIZHUB 200
Service mode, but if you clear the counter without replacing the drum image problems and code can appear on the machine. Machine bases certain voltages on certain assy's. for example drum and developer based on what the counter says because that is the only way the copier knows it got a new drum and or developer..
Sep 28, 2012 | Minolta bizhub 200 All-In-One Printer
Minolta Dialta Copier Di152, code reads 32-COF
Replace the developer and developer unit. And Replace the drum normally done together make sure to reset the drum developer counters because the machine use the counters to set voltages to the drum and developer and it is the only way the copier knows it has a new drum and developer reset the counters without replacing the drum and developer causes code sand image problems
Sep 16, 2012 | Minolta Office Equipment & Supplies
Please help!!!! I am having problems with a Di2510 machine. When it is turned on I get the 'Please Wait' screen It just stays frozen on that message
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Also try removing the toner bottle, turn off the machine with the toner bottle out and cover closed turn on the machine when it ask for toner properly place the toner bottle in the machine
Aug 11, 2011 | Minolta Di2510 All-In-One Laser Printer
New drum
It is important that you replace the drum when the machine is saying "REPLACE DRUM"...NOT when it is saying "REPLACE DRUM SOON".
When the machine says "SOON" it is advising to have a drum on-hand ready for replacement. The machine will still be able to print pages. When the machine says "RPLACE DRUM" it will no longer print and a new drum cartridge must be installed to reset the indicator.
Jun 04, 2010 | Muratec F320 Plain Paper LED Fax
My washing machines is flashing on door code it is hotpoint aquarius plus wf740 ,the door is fully closed so i do not know what the problem is help please
This sounds like the interlock has failed. The door latch connects into a small electronic device inside the machine and if this fails the door will not lock and therefore the machine will not function. To replace this, power off the machine. open up the door seal and inside where the latch goes in you will find the interlock. replace that.
May 23, 2010 | Washing Machines
New drum
Apr 25, 2010 | Brother IntelliFax-2820 Laser Fax
DRUM LIGHT WILL NOT CLEAR
As far as I know there is no "manual" way of resetting this. The new drum has a small glass fuse which should blow when it is placed in a machine for the first time. It is the machine "seeing" this fuse blow that resets the message.
Are you using a "new" drum or one that has been in another machine?
You can try to fit a new fuse to the drum.
May 14, 2009 | Muratec F320 Plain Paper LED Fax
Canon np 1010 copier
There is a Drum UNIT for your machine that I think is User friendly. Just order the Canon Brand, and if the unit is User Friendly, they place instructions on how to replace it in your machine. Your best bet is to find a company online that has a Canon Brand Drum unit in stock, and also a toll free phone number, and when you call them up, ask them if the drum unit is User Friendly (Customer Replaceable) if so, then order the drum unit (not just the drum by itself, but the unit is recommended) and replace the unit. This should take care of the line problem that you are having.
IF you want to be sure about the lines on the drum, get a flashlight and look inside the machine and on the drum. After making a copy and having lines show up on your copy, turn the machine off, open the front door, and machine. Look inside with a flashlight by the drum. If you see lines on the drum, then you know the problem is in the drum unit.
Hope this helps.
FYI, Canon Drum units on a couple sites goes for 95.00 - 125.00.
Good luck.
Feb 08, 2008 | Office Equipment & Supplies
Brother IntelliFax-2820 Laser Fax Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
