Question about Acer AL2416WBSD 24" Monitor
LCD Screen blank
LCD screen doesn't display. It is blank. However, the monitor does detect a signal (power light truns green)
    President:
  • 1,561 Answers
The picture board on your monitor is bad, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on Apr 25, 2010
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
Tip
Troubleshooting Flat Panel Monitor issues. Screen is blank and power indicator...
Screen is blank and power indicator is off
The monitor is possibly not receiving power. Perform the following steps to fix the problem:
  1. Ensure that the electrical outlet and the monitor are both switched on.
  2. Check that the power cord is firmly plugged into the electrical outlet and the power supply unit.
  3. If the power cord has a removable fuse, replace it.
  4. Try another power cord.
  5. Try another electrical outlet.
  6. Check the power connection at the back of the panel.
Screen is blank and power indicator is steady green
Brightness and Contrast may be too low. Adjust the brightness and contrast using the On-screen display controls (OSD) by selecting the button
Screen is blank and power indicator is steady amber
The monitor is in the Power Management Standby state. The power management feature is invoked when the computer recognizes that you have not used your mouse or keyboard for a user-definable period. Perform the following steps to bring monitor out of the power management state:
  1. Press any key on the keyboard or move the mouse to restore operation.
  2. Check the Power Management software on your computer.
  3. flatpnlmont12.jpgPress the (OK) key to switch between analog and digital mode. If the panel is the wrong mode for the signal being provided, the monitor appears to go into sleep mode.
Screen is blank and power indicator is flashing green
Display mode of the computer is outside the range of the monitor. The display mode the monitor uses is controlled by your computer. Therefore, you should refer to your computer's documentation for details on how to change display modes.
The image size, position and shape may change when the display mode changes. This is normal and the image can be readjusted using the IMAGE SETUP and the monitor controls.
Note: Unlike CRT monitors, which requires a high refresh rate to minimize flicker, TFT technology is inherently flicker-free. If possible, configure your computer for 1600 x 1200 addressability at 60Hz vertical refresh rate.
Use the following table as a guideline and reconfigure your computer to use a supported display mode. The highest resolution (for example, 1600 x 1200) produces the optimal output, but limitations of your monitor may prohibit this setting. Adjust the addressability mode until an image appears.
CHECK SIGNAL CABLE" message is shown and power indicator is steady amber.
The monitor is not receiving a video signal. Perform the following steps to fix the problem:
  1. Check that the signal cable is firmly connected to your computer
  2. Check that no pins are bent in the signal cable connector.
There are noises in the video signal. The IMAGE SETUP function is used to adjust the level of noise in the video signal which causes horizontal lines or areas where the image appears to be unstable and jitters or shimmers. This can be done automatically or manually.
Note: It is not applicable to digital input.
Use the image setup fix the problem:
  1. flatpnlmont6.jpgSelect (Image Setup) menu in the OSD.
  2. Select Manual to adjust CLOCK/PHASE settings.
Image appears to be discolored
The color setting may be incorrect. Perform the following steps to adjust the color settings:
  1. flatpnlmont8.jpgSelect (Image Properties) from the OSD menu.
  2. flatpnlmont9.jpgSelect (Color Properties) to adjust the color mode you find most comfortable or fine tune the colors using the Custom menu.
A few dots are missing, discolored, or inappropriately lighted
A small number missing, discolored, or lighted dots may be present on the screen, which is an intrinsic characteristic of the TFT LCD technology and is not an LCD defect.
Using On-Screen display (OSD) controls
flatpnlmont12.jpgThe settings adjustable with the user controls are viewed through the OSD. Press the (OK) button to display the main OSD menu.
OSD main menu:
Note: The LCD monitor needs time to become thermally stable the first time you turn it on each day. Thus, to achieve more accurate adjustments for parameters, allow the LCD monitor to warm up (be on) for 15 minutes before making any screen adjustments
on Aug 08, 2010 | Televison & Video
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
LCD monitor went blank
Which model is it?Does power led remain on?
Samir
Jan 22, 2008 | BenQ FP737S-D 17" LCD Monitor
No signals. screen is blank. power green light is blinking.
Its not a malfunction. blinking light is indicator shows that no appropriate input signal detected. If you are using laptop refer your user manual to toggle to external display device. For example in most of the Toshiba Laptops requires to use Fn+F5 in order to use external display device like you have. If issue still persist you may post again by including the details of your laptop/desktop model.
Good Luck, Happy New Year
Nov 09, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Monitor Acer Problem
I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
Monitor temporarily on
Hi, It looks like it may be receiving power from the computer but not a signal. Try a different monitor cable from the PC and even a different monitor. If doesn?t work, it could be the graphics card in the PC. Daniel
Feb 16, 2006 | 3G Technology GM-171B 17" Flat Panel LCD...
Acer AL2416WBSD  24" Monitor Logo
201 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
