Question about Marshall 15 Watt Guitar Amp
Whats the impedance of the loudspeaker of a Marshall G15rcd ? I want to improve the sound of it.
  • Marshall Master
  • 5,603 Answers
Almost all of these small 15 Watt units run 8 ohm speakers...
Do NOT expect to get much improvement from changing speakers.
Posted on Apr 25, 2010
Marshall Amplification Marshall MG2FX Guitar Combo Amp power turns on but no sound
Hi!
At this point, I would just take it to a tech rather than poke around in it. It sounds like the power section is the problem as you have guessed, but without the technical knowledge you'd be shooting in the dark. That particular amp is right on the line of being expensive enough that would be worth repairing, but you might do just as wel to check Ebay for another used one.
Good Luck!
May 21, 2014 | Marshall Amplification Marshall MG2FX...
Need repair manual for g15rcd marshal amp
found one here :-
http://www.eserviceinfo.com/download_start.php?downloadurlid=48727
Apr 14, 2013 | Marshall Amplification Music
Can i connect 2 jbl 300 watt speakers to the mg 100hdfx 100 watt amp head ?
Yes you can as long as the speaker impedance when paralleled doesn't go below the rating of the amp. Marshall seems to hide their design lowest output impedance. Possibly you can find that in your owner's manual. Then find the impedance of the JBL. If half the JBL impedance is equal to or greater than the lowest impedance the Marshall is rated, you are fine to use it. The speaker Watt rating should always be bigger than the amp rating which it is in this case.
Dec 11, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I have a Marshall MG100DFX. I turned my amp on a few days ago and I heard this loud sound (not the standard hum/buzz that you hear when you plug a guitar into an amp; it sounded more like a foghorn). Now,...
I would try hitting the side of the amp before turning it on. There may be a loose piece of solder or other conductive particle stuck somewhere. Bang the cabinet rather hard with your fist. If that doesn't help it might be a loose solder connection at a resistor or capacitor but a tech should check that out.
Dec 04, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
I want to know how much my marshall g15rcd amp is worth
Used small amps don't bring much money...
The best answer can be found by searching for COMPLETED ITEMS on eBay for like items.
Oct 03, 2010 | Marshall 15 Watt Guitar Amp
Marshall DSL 401 runs fine for about 10 minutes from cold then starts to crackle and sound disappears The amp is fairly new with not a lot of use
if this a tube amp then your tubes might be going bad. but if it is a solid state amp then im not to sure whats going on.
Mar 01, 2010 | Marshall Amplification Marshall MG250DFX...
I want to know what is the resistance value R32 - marshall g15rCD 15 watts
The value of r32 on the g15r cd amp is 10 Ohms 1/4 watt Brown-Black-Black
Dec 20, 2009 | Marshall 15 Watt Guitar Amp
Left input for loudspeaker is dead? speakers both work out the left but neither on the right. can I fix it myself? marshall mg250dfx thanks
It sounds like the speaker output jack is broken or it has come unsoldered from the circuit board. You can fix this if you have enough electronics experience but you have to be very careful as components in an amp can carry a lethal charge even after being unplugged. You can partially discharge the capacitors by unplugging your amp from the power source with the speaker plugged into the working jack and set at a low volume while turned on ( not on standby ). If you feel at all uncomfortable attempting the repair yourself you are far better off taking it to a repair shop preferably one with experience with Marshalls. The same is true for other brands as well. Please let me know if this helps.
Nov 18, 2009 | Marshall Amplification Marshall MG250DFX...
Sound fades after 15-20 minutes
There may be thermal sensor that protects the power amp that is sensing over temperature and turning off the power amplifier stage.
Try cooling with a fan and see if it lasts longer. If you are obstructing the cooling in any way, try to avoid that.
As a test, leave on for an hour and THEN try driving sound. If it works for a while, then driving is what is overheating it.
VERIFY that you are NOT running too low impedance speakers!!!
Most amps will drive down to 4 ohms. That is a single 4 ohm speaker or two 8 ohms in parallel MAX.
Sep 09, 2009 | Marshall Amplification Marshall MG250DFX...
No output
There are some possibilities. One, your speaker may be blown or disconnected. Make sure the wiring is still connected to the speaker and if you have one, try measuring the resistance(impedance) of the speaker with a volt ohm meter.Do this unplugged from current and disconnect one of the wires from the speaker or you will get a reading from the output stage. Two if there is a heaphone or line out jack it may have become faulty. If you have sound with the headphones plugged in your amp is still producing sound. Some jacks are designed to interrupt the signal to the speakers allowing you to practice without bothering anyone. If your amp has that feature and you still have sound with the headphones and your speaker tests OK then your problem is the jack. Hope this helps.
Jul 20, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall 15 Watt Guitar Amp Logo
239 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
