Question about Minolta X-700 35mm SLR Camera
I checked the TTL flash contact at the right side of the X700 hot shoe, but no TTL flash control, instead the flash unit gave a full burst.
  • MIke May 11, 2010
    If you are shorting the camera out it will not TTL. How are you checking the contact ? Is the flash you are using TTL for minolta x700? are the contact on the flash and hot shoe clean?
  • 302 Answers
This could be several things. From loose/dirty cable connectors to circuit board issues. It could totally be just the age of the batteries and capacitor in the flash taking a long time to charge, making it look like it took full power. Put in new batteries or take out the old ones, rub the contacts on your jeans, and put them back in.
When you quit laughing, this actually works. It removes that thin patina that develops on the battery terminals over time.
It's also possible that the flash sensor is dead, but that's the least likely item.
Posted on May 03, 2010
TTL Flash compatable with pentax K-7
To let a flash work in TTL mode the camera and flash must be from or made for the same brand. Like Metz for Nikon, the Through The Lens measuring of the light, will only work with Nikon camera's. If the Vivitar 850 was compatible with Nikon, you only can use it in TTL mode with a Nikon. If you want to use it on another camera, you have to set the flash and the camera to manual. (sync speed is not allowed to be shorter tan the manual of the camera says..)
The hot shoe should have the same connection. most brands do have their own hot shoe. And never use an old flash or speed light in a digital camera, because with the old ones the high voltage can pass through the hot shoe to the electronics in the camera, damaging the camera.
Jul 13, 2014 | Vivitar 850AF for Nikon TTL Flash
Connection to Rolleiflex SL2000F SLR
I checked out a SL2000F that had good pictures on eBay. I see a standard hot shoe on the side of the camera. That being said, neither a standard shoe connection nor a pc outlet will give you TTL on the Metz. TTL is Transistor to transistor logic (or for camera store people, through the lens) A sensor that reads the light from the actual plane of the shutter is required to allow the Metz to give TTL operation. It will work on the Auto setting, but the Rollei does not have the sensor as described.
Feb 18, 2008 | Rollei SCA 356 Flash
Test button- fire, but when attached to hot-shoe (camera or trigger) doesn't fire. Why?
Check the hot shoe contacts and make sure they're clean. If that doesn't help, place the flash on your camera, turn both on and reset the camera to factory default through the menu settings. Also make sure the hot shoe on the flash and the camera isn't damaged. Have you tried the flash on another camera?
Aug 09, 2013 | Canon Speedlite 430EX TTL Flash
I have an SB-800 which has worked great for a couple of years. Lately it is only firing every 8 or so times and seems to be loose on the hot shoe.
Check that the contacts are clean, and have not been bent out of tolerance on either side. If that's not it, there are a couple screws in the unit that may need tightening.
Jun 16, 2011 | Nikon Speedlight SB-800 TTL Flash
I just purchased a Rebel T2i and a 580EX II Speedlight. After approximately 50 flash photos, the speedlight shifts slightly to the rear and it appears the contact between the speedlight and camera...
It would appear to me that the flash was not locked in position and has move back on its mount which would cause the flash to go into complete manual mode or loose complete communications between camera and flash.
I would suggest shutting the camera and flash off remove the flash first unlock the little locking leaver on the bottom. The 580EX and the 580EX II differ in that the 580EX II has a leaver rather then the huge locking screw. Once apart reinsert the flash unit back into the camera hot shoe making sure that the forward edge of the flash mount is seated as deep into the Hot Shoe as possible and lock it into position. It should click into lock position. Biggest thing I have with my "crew" is when there is a flash installed on the camera they pick the camera/flash unit up by the flash that's a real bad thing cause the flash mount is light plastic and it'll ether break, twist or even unlock the flash enough that the camera falls off of the flash. Pick the assembly up with both hands lens and body. I'm not saying you are doing this but when my crew/working associate's do this I'm not happy.
Although that new switch idea is great it also can be unlocked without noticing.
Diagram
Jan 06, 2011 | Canon Speedlite 580EX II TTL Flash
Flash contacts are not pressed tight against the camera contacts... will only fire in certain positions. do i have to take the flash appart to do something with the contacts (like bend them or something)...
You can try to carefully bend the support arms on the hot shoe, bend them down so the flash is tighter to the hot shoe connections. But be careful you do not bend them too much.
Jul 13, 2009 | Nikon Speedlight SB-600 TTL Flash
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
Vivitar 3200 Flashgun and Canon EOS 400D
Using Vivitar 3200A flash gun on a DSLR is risky for the following reason. The trigger voltage of a DSLR at flash hot shoe that takes it to its TTL (through the lens) circuit is less than 10 volts, it is about 6 to 8 volts in the recent DSLRs. The trigger voltage generated by Vivitar 3200A at full charge flashing is around 180 volts (max). That is a fatal dose for a sensitive DSLR TTL circuit. This high voltage flash gun will work endlessly, the only damage is to the TTL flash circuit. When you attach a TTL flash to the DSLR after using Vivitar 3200A for sometime, your TTL flash will not communicate with your camera. It will be just another ordinary flash without any auto functions. There is a Wein adapter that you can fix b/w your cameral hot shoe and the vivitar flash gun that is said to reduce the trigger voltage that passes into the camera. Try it if you get it. Without this gadget it is better not to use non recommended and non TTL flashes on latest DSLRs.
Apr 13, 2008 | Cameras
Auto Function Failed
It could be a communication error between the flash and the camera. Check the shoe foot for any damage or stuck pins. All of them must make proper contact with the hot shoe on the camera to get full auto/TTL, same for the shoe of the camera, bent? dirty contacts?
Dec 31, 2007 | Nikon SB-28DX TTL Flash
Minolta X-700 35mm SLR Camera Logo
56 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
