Question about BenQ FP91G+ 19" LCD Monitor
Can't get monitor to turn on
I turn the monitor off and now when I try to turn it on the light comes on for a moment but it won't turn on completly. If I hold the button down the light blinks but nothing happens
  • 11,361 Answers
Dell has the same problem as BenQ since BenQ makes the monitor for Dell and HP. Please look through the Dell albums so you will know what to look for inside, bad transistors, caps, solder joints.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Apr 26, 2010
The monitor won't get power
have you tried different outlets?
Feb 03, 2013 | Sony SDM-HS73P 17" LCD Monitor
My light won't ignite on my mpi 441 monitor
this morning my heater, monitor 411, was running fine as always.
while it was running the power company came to work on a pole and turned the power off. it was down for about three hours. once power was restored it wouldn't come on.
the pilot light is off but I'm not sure if it's suppose to be while not running.I've tried priming it with three pumps, resetting by unplugging, beleeding the line, all don't work.
it's suppose to be 22f tonight so I could sure use some help.
oh, I have a manual but, of course, it doesn't cover the problem. I also called the company but got a voice mailbox...go figure.
somebody please help!
Dec 20, 2012 | Heating & Cooling
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
Kindle Touch won't start
Bad battery, needs changed.
Nov 09, 2017 | Computers & Internet
When i turn on my pc, the cpu works perfectly while the monitor "syncmaster591s"....when i turn on the monitor the light (green) beside the button of the monitor is blinking
Try a different monitor...if the different one won't come up then the prob is your video card in the computer...if it does work then the monitor is defective...it would probably be cheaper to get a new monitor than to have the syncmaster fixed
Apr 27, 2011 | Computers & Internet
When i turn on tower a blue light comes on, the monitor comes one for a moment an says power saver and then it goes off.
This means that your monitor is not getting any signal from your video card. Check if the monitor cable is properly plugged in. if it is try connecting another monitor to your tower. If That fails theree must be some problem with your video card..
Feb 28, 2011 | Computers & Internet
I was running my Toshiba Satellite A135-S2376 when the screen completely froze. The cursor wouldn't move, and I could not restart the computer with control-alt-delete. I held the power button until it...
It sounds like they had something with that last entry; if you've used it a while it's common for the wires connecting the screen to the machine to fail, resulting in about what you described. Of course you've tried the monitor hotkey (for switching simultaneous/separate display with connected monitors) already as well as closing/opening the thing to see if the display reconnects for the moment....
Otherwise it's pretty vague what might be wrong; it could be a PC CARD cellular interface came out a bit or caught EMI, knocking out the system board (permanently or not) or any number of screen (and connection) related issues. Try running with an external monitor, looking for junk in your laptop's ports, and certainly swapping out your hard drive with one you don't mind sending for warranty service (or at least completing some sort of backup on another machine.)
Jan 05, 2011 | Computers & Internet
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Monitor problems
It seems that you are trying to use a graphic mode that your monitor doesn't support.
Restart windows in safe mode, go to Control Panel. Click on Display. Select settings and change to a resolution that is supported by your monitor (I don't know your model, but 1024x768 is a safe bet).
Restart the computer.
It should be working by now.
Dec 21, 2008 | Relisys RLT1720 17" LCD Monitor
BenQ FP91G+ 19" LCD Monitor Logo
421 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
