Question about Kenmore 30 in.44084 / 44089 Electric Cooktop
Left burner is not working
My left burner stopped working. How would i replace the electric element
    President:
  • 2,468 Answers
These elements merely unplug when you lift up the one side of the element,then just easily rock back and forth till it unplugs from the stove top
Posted on Apr 25, 2010
How do I fix my left rear burner that has stopped working?
First of all, you need to test the wiring to that burner. If there is no electricity, then you need to replace the plug in. You can get them at an Appliance parts store. If there is electricity, then all you need to do is get a new burner at Lowes or Home Depot. Sometimes the burner gets a tiny crack in the burner that breaks the continuity.
Sep 01, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
GE profile JP969 fault code F113
I took the cooktop apart I removed the terminal from the main electronic board . The left front burner has 2 white wires and 2 yellow (my case). The 2 white wires lead to the RTD sensor.With an electric meter set on OHMS check continuity between the two wires leading to the RTD sensor .If the reading is more than 1030 ohms is good if not than you need to replace the whole burner that comes as a complete unit with sensor and ribbon heating element.I found it on line for $114.00 +shipping.I wish they sold only the sensor but it would've been too cheap and not worth it for the makers . All connections to that burner are very easy put back together . Some suppliers may ask for as much as $175-$195 for the complete unit .
Apr 11, 2012 | GE 36 in. Profile JP969 Electric Cooktop
I get an error message F113 for one burner
This indicates failure (open circuit) of the left front temp sensor. You can search for my solution for replacing a element on a JP939 and JP969. Will likely require replacement of the element (~$160).
Mar 24, 2011 | GE 30 in. Profile JP939 Electric Cooktop
Burner light stays on
This is caused by a faulty sensor that is located between the burner element and the top. To replace the faulty part you will need to uninstall the cooktop and remove the glass top. The sensor is a rod a little smaller than a pencil that you will see right on top of that burner.
If you choose not to replace the sensor it will not cause any issues other than you will have to live with that light constantly on and you will know when the top is hot for that element.
Jun 19, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
The main burner (left front) only heats on half the circle.
Your referring to an electric range I'm assuming. In that case the heating element is only heating to a mid-point then stopping. This typically means the heating element is burnt or is partially burned out. The element is usually user replaceable and requires the old one be unpluggude and replaced with a new one. You'll need to get the element from the manufacturer.
Apr 21, 2010 | GE Cooktops
We have a Jenn-air JGC8430ADS. The rear left
WE have a Jenn-Air JGC8430BDW gas cooktop. How do i replace a broken ignitor?
Feb 13, 2010 | Jenn-Air Cooktops
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Kenmore Stove
Check the wiring first, but it is usually the element. When they burn out t hey usually short to ground.
May 15, 2008 | Maytag MEC5430BDS Electric Cooktop
Jen Air left front small burner does not heat up.
these are cartridge elements corrrect? try reversing the cartidges, now the front small will become the rear small . does it not work in this position? and the newly placed front burner work?? this will determine if the proble lies within the cartridge or the switches
Feb 22, 2008 | Jenn-Air JED8230 Electric Cooktop
Kenmore 30 in.44084 / 44089 Electric Cooktop Logo
144 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
 Fix Your Board
Fix Your Board
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
