Question about Kenmore 24032\24036 Top Load Washer
Wont spin during cyle - Kenmore 24032\24036 Top Load Washer
  • oldguy5 May 11, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since top load and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem. Have you tried a different cycle??? Can you hear the motor???? Can you smell anything unusual???? Does it make any strange sounds (grinding etc.)???
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
Washer won't spin on spin cycle but spins during other cyles
Hello rylee1966 - From what you are describing, it sounds like the washer agitates, but it will not enter a high speed spin. If that is correct, more than likely there is a door switch failure. I will personally recommend contacting a professional to move forward accurately and to assist with the repair(s).
Feb 23, 2013 | Frigidaire Affinity ATF7000E Front Load...
My whirlpool machine does not spin properly and there is always water left after the spin cycle, when its turned on it will stop after spin cycle like its finished but there is still a lot of water left in...
hi, it sounds like one of two possibilties, will try and help out. The first thing to check is whether the water/drain pump is actually working fine, i think it blocked. Secondly the pump may also be overheating and malfunctioning during the cyle, run it without clothes and check the flow of the drain during the drain/spin cycle and take it from there.
Jun 14, 2011 | Whirlpool Washing Machines
Ou washing machine doesn't spin rapidly during the wash cyle or spin out. It does spin in the spin only cycle.
your transmission is failing, or have a loose drive belt
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Washing Machines
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
It is leaking during the washing and ring but not the spin or drain
Check to see if the washer inner tub is spinning during the agitation. If it is it is causing the water to spin up and over the side during the wash cyle. Bad brake package and usually not worth repairing. You can also have too much high sudsing soap in your washer, causing it to over flow out the safety overflow pipe. Good Luck Appliance Specialists.
Dec 14, 2009 | GE Washing Machines
Spins during wash and rinse cyle, but not enough for the water to spin out
is it overloaded take out a third of the clothes ad redew the spin cycle see if this works
Nov 29, 2009 | Cars & Trucks
Spin cyle
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Hope it may help you;
Regards,
VOTIT
Sep 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont spin out
are the clothes out of balance? sometimes it can take quite a few trys to rebalance the load. if that is the case, it probably could use new drum springs.
Mar 05, 2008 | GE WSRE5260D Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
48 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
