Question about Sony STR-DE545 Receiver
The center channel on my Sony STR-DE 545 occasionally cuts out. It can happen with either the cable settop box or the Bluray player as the audio source. In either case, I use a digital optical audio input to the STR-DE 545. I've found that I can usually get the center channel to come back by turning the amp or the settop box or Bluray off and on again. However, the most reliable way to get it to come back is to unplug the digital optical cable and then plug it back in. Not really acceptable thought since it's a hassle to climb behind the equipment in the middle of a movie. Any suggestions for a permanent fix other than replacing the amp?
  • cjoubert160 Apr 25, 2010
    I'll try this next time it happens and let you know. However, if it's a cold solder joint, would it make sense that I can get it to work by unplugging and plugging back in the digital optical audio cable? This has been working without even touching the amp, I can unplug/plug the optical audio at the settop box and it resets the audio.
    President:
  • 2,468 Answers
It sounds like a cold solder joint,can you lightly tap on all sides and top and bottom the amp when it does this and see if this makes it operate again,if so then I would say you have a loose connection or cold solder joint inside the unit
Posted on Apr 25, 2010
  • danny Hendrickson Apr 25, 2010
    YES.possibly because if there are bad solder connections and just enough circuit board movement/vibration could "self-heal" the problem for a time in this area ,also plugging in and unplugging will in some cases create a very minute(small arc) to actually temporarilly weld this connection,then enough vibration will re-break this electrical connection again,
  • danny Hendrickson Apr 26, 2010
    yes,by unplugging and plugging the unit back in,your creating small surge voltage/healing transients,the same as small arcs,try it and let me know the outcome,you wont hurt the system this way,but try to get this repaired anyway,there are M.O.V.'s and Zener diodes in the circuitry to protect these kind of surges/overvoltage transients..thank you .daniel
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
Sony STR-DG1000 HDMI video not displayed
That's strange, does the monitor work with regular av cables or and s-video cable ?
Dec 27, 2007 | Sony STR-DG1000 7.1 Channels Receiver
How do you connect sony str-de 698 fm receiver to television, cable box and cd player
Connect it's two audio plugs, likely to be coloured red and white, to corresponding sockets on any device that has them and select that input on the device. You should then hear your tuner.
Depending on FM signal strength where you live you may need an aerial, some is always better than none.
Sep 21, 2011 | Sony STR-DE698 Receiver
I have a sony str de-475 amplifier and the centre speaker stops working after about a minute. leave amp powered down for a while and it works again but only for about a minute
Try replacing the center speaker with one of the left or right speaker and run it for sometime ( do not connect the center speaker to any other channel ). If the system does not cut off the center speaker connection this way indicates a short in your center speaker.
But with the L/R speaker if the system still stops working you have a hardware problem and will need professional help to fix. 5.1 amps are complicated and difficult to access even for an experienced technician.
Jun 22, 2011 | Sony STR-DE475 Receiver
STR-DE835. White noise coming ferom right rear speaker when DVDs are played. Twise the word "PROTECT" has been displayed.
IF any other source plays fine with the RR speaker, and IF it only happens with the DVD player and IF you're using the 5.1 analog audio feeds to the STR, maybe the audio on that channel is **** from the player. You could prove that by temporarily swapping the RR input from the DVD to any other channel input and test it at a medium level.
If it stays with the DVD RR output, the player or the cable would be suspect. Swap in a different cable and make sure it is not routed uniquely near any sources of magnetic fields, motors, UV or track lights, etc.
If you're using digital input all that advice was a waste of time to create as there is nothing external to the chipset that could affect one input channel. Try a different digital input on the STR.
Jan 30, 2011 | Sony STR-DE835 Receiver
Center channel cuts out during movie, a click noise is heard and the center channel cuts out. I checked all the trouble shooting items with no luck.
Check the solution posted by "bikes" at http://www.fixya.com/support/t102695-sony_str_de845_center_channel_cut_out
Nov 25, 2009 | Sony STR-DE475 Receiver
I have connected my Charter HDTV settop box to the strdh700 in the 'sat in' hdmi connection, then connected the 'out' hdmi to my sony bravia tv and the signal isn't getting there. any suggestions?
If you're not getting the audio signal, please select the Audio for HDMI to TV+AMP in Menu display. If you're not getting the videos, please check if the TV is HD ready and supports 1080p signals. Also check if the connections are firm and secure and you selected the correct input on both Receiver and TV. Please try connect the Settop box to different HDMI port of the receiver and try. You can also try connecting the Set top box to tv directly and check if its working. If its working fine directly with the TV, you may try to replace the cable and try else the receiver may require service
Sep 22, 2009 | Sony STR-DH700 A/V Receiver
My Sony DE 945 Blue LED light indicating digital audio reception
Does anyone have a solution? The authorized Sony repair center in my town is stumped.
Jan 16, 2009 | Sony STR-DE945 Receiver
How do I hook the STR DE 575 up to my tv?
Usually if you have a Cable or Satellite box, you would hook up a Fiber Optic or Digital Coax cable from the Sat/Cable box to the Sony Receiver. Then for HD, an HDMI cable or componet cables from the Sat/Cable box to the TV
Dec 18, 2008 | Sony STR-DE575 Receiver
Sony STR-DA5000ES 7.1 Receiver
its for digital decoding of the sound source. You need to connect a digital cable (ie optical) from the DVD player to the optical input in the receiver. The receiver should then decode the source into multichannel components ie 5 channels for example
Jul 23, 2008 | Sony STR-DA5000ES Receiver
Sony STR-DE545 Receiver Logo
162 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
