Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
The paper won't go in! I can hear the thing clicking but it wont pull the paper in.
  • 428 Answers
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Posted on Apr 25, 2010
I was driving my chevy 1500 and it died and does not seem to be getting any gas
if truck was made after 1988 its sure to have some sort of PCU module and the later types even will tell you exactly why it wont run , but you'll need to hook up a code reader to see what the problem is , but a owner can diagnose some things themslefs , just by using there good hearing .
start by turning key to run not start listen !! did you hear fuel pump prime in tank ?? then shut off this is telling you fuel pump ckt is ok may take several times to hear it
crank engine over listen to fuel injectors click on engine top (takes two people) injectors actually click as they are opened for fuel ?? a old paper towel roll tube held to your ear helps to hear
Aug 05, 2016 | Cars & Trucks
My heil heater is not firing up
take the hose off the exhaust fan assemby and suck on the end and you should hear it click try sticking a paper clip or something like in the hole where the hose coonnect on the exhaust hosing sometimes some junk just gathers there
Jan 18, 2013 | Honeywell Furnace Air Pressure Switch...
How do I clean the rollers on lexmark x2500
You can try to clean the rollers with a cotton bud to reach it.
Leading cause of paper misfeeds is debris or foreign objects that accidentally fell into the paper feed area. Grab a flashlight and look into the feeder for any obstructions.
Dec 24, 2011 | Lexmark X2500 All-In-One Printer
My paper jammed, I (of course being inpatient) pulled it out and now the paper wont feed. Please help.
To fix the error 5200 or E2 or paper won't feed
1. Open the cover printer
2. The right side of the printer, there is a round plastic. Rotate the plastic or gears, as opposed to clockwise
3. Rotate the gears, until you hear the a voice from the right side of the printer (voice shifting gears on the right side of printer). Aiming to restore the position of the skid gear.
I hope this information helps. Thanks.
Oct 18, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Wont accept paper
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 15, 2009 | Office Equipment & Supplies
PAPER WON"T LOAD
The problem is software rather than mechanical operation. Uninstall the printer driver from the Add/Remove section of the Control Panel. Pull out the USB port and replace it back. This will prompt you pc to install the driver of the newly found hardware. Reinstall the printer driver. Should your printer be observed to have the usual problem, replace both cartridges with a one. "Loading paper" problem feedback is the same prompt as what you get when cartridges are old or refilled with unauthentic ink.
Feb 03, 2009 | Canon PIXMA iP1600 Printer
BROTHER MFC-8460N ALL-IN-ONE
I had a similar problem, more of a snapping sound than clicking, but this is what worked for me - pull the paper tray out and "loosen" the rear paper limiter by unlocking it, move it back about 1/8-1/4" and then re-lock it
Aug 19, 2008 | Brother MFC-8860DN All-In-One Laser...
Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
85 people viewed this question
old marine
old marine
