I need white smoke activation key please help
What is the poss!ble cause for AC not to fountion
White smoke means the engine is burning oil. Cause of smoke can be worn piston rings and worn valve stem seals. In any event,continuing to drive it that way will run the engine out of lubrication oil. AC not functioning can have many causes such as loss of freon from a leak in the system, burned out clutch on the compressor, failed safety pressure switches ro a burned out relay or a fuse.
May 29, 2016 | AC Cars & Trucks
Blueish white smoke comeing from exhaust
Hello There
White smoke when first started is normal. If white smoke continues you have an internal coolant leak, i.e., cracked head/blown head gasket.
Black smoke is caused by a rich fuel condition.
Blue smoke is caused by oil consumption.
You need to check your oil cap for yellow/white gunk on the cap if you have this then this is a sign your head gasket is cracked. Check to see if your radiator coolant level is down this is also another sign.
Hope this helps. Please don't forget to rate me.
Many Thanks
May 20, 2009 | 2004 Chrysler PT Cruiser
Car has some white smoke by oil pan which happens after heat is turned on. Smoke is coming from under the oilpan maybe.
White smoke usually means coolant getting into engine and burning. The smoke will find the easiest place to come out. The reason it happens after heat is turned on is the coolant is active more
Mar 15, 2016 | 1997 Dodge Neon
2008 yamaha r6 white smoke out of exhaust and when i cut the bike off it will not start again
Sounds like it overheated. White smoke can be oil but, with it not starting sounds like coolant and it overheated. Take it to a repair facility for confirmation.
May 16, 2012 | 2008 Yamaha YZF-R6
White smoke coming out of my yamaha 2008 r6 whenever i start the bike. why is the white smoke coming out ?
Hi, Anonymous your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. WHITE SMOKE on start-up can is usually caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers.
2. BLUE SMOKE on start-up is usually caused by failed valve seals. Smoke that is constant while riding is usually caused by valve to guide and piston ring clearances that have exceeded service wear limits.
3. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/205697-white-smoke-exhaust.html
White Smoke Coming Out My Exhaust Please Help
2008 2009 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 28, 2012 | 2008 Yamaha YZF-R6
White smoke comming from the left side of the egine
If your smoke is coming out of the tailpipe......White smoke usually means that water or antifreeze is being burned by your engine, blue smoke is oil and black smoke is fuel ( too much fuel) . If it is coming from under the hood you need to figure out where it is coming from.
Jan 01, 2018 | 2002 Hyundai XG350
I have a diesel engine that expells white smoke for 5 to 10 miniuts after start up? The exhaust also smells rich with fuel? I bought the truck used and am trying to fix the problems! Please help.
When an engine expels black smoke it means that the piston rings are going and is consuming oil. And when the color of smoke is white the engine is consuming more fuel. Both are harmful. Black to the engine and pocket while white to the pocket. It seems that the injector need careful attention.
Cold engine does expel white smoke initially. When the temperature rises to normal working temperature the smoke stops. This is normal in your case. 5 to 10 minutes to warm up is normal for any diesel engine. But any thing more than that needs attention.
Oct 04, 2010 | 1988 Ford F 250
White smoke out the exhaust
You will need to check head gasket. Please check the oil for coolant (milky deposition or presipitation). Also check if you loosing coolant and if coolant has oil in it.
Please kindly let me know if you need more info
Good Luck
Feb 14, 2009 | 1990 Ford F150
Computers & Internet Logo
511 people viewed this question
David Payne
David Payne
