Question about Ducane 30400040 Stainless Steel Grill
Side burner on my Ducane 30400040 LP gas grill has a tall yellow/orange flame. How do I adjust?
  • 4,070 Answers
Try blowing the burner out with compressed air. They're not adjustable but can get clogged up and change the air to gas mix.
Posted on Apr 25, 2010
I cannot find a supplier who can provide an LP to nat gas conversion kit for my 4 burner grill made under the name: Ducane, model # 30400040. Can you assist? Marlin
Perhaps, the reason you can't find the fuel conversion parts is that they are not convertible from one fuel type to another. Ducane/Weber makes both an LP model and a Natural Gas model of your grill, but no conversion kits. Because, as the Owners Manual states "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty."
http://help.weber.com/manuals/ducane/2009%20Manuals%20pdf/Affinity_3400_4400_NG_OwnersManual_27010342_061008.pdf
Certainly, you could attempt it, Marlin . But it's not the wise thing to do.
I know this wasn't the answer you may have wanted, but I hope it helps you.
May 06, 2011 | Ducane 30400040 Stainless Steel Grill
I replaced the burners under the grill and the gas is is flowing with a very small flame but i cant get it to have a large flame. what can i do?
Easy solution. Turn off your propane grill tank. Disconnect the hose from the tank, Wait 5 minutes and reconnect the hose. Now, turn the tank vale on very, very slowly, until it full open. Then light each burner one at a time. Turn the flames to high.The burner flame height should have returned to normal.
Remember to turn the tank on very, very slowly each time after turning the tank off.
Happy Grilling!
Feb 11, 2011 | Ducane 30400040 Stainless Steel Grill
Does conversion from LP gs to Natural gas on Ducane 30400040 (essentially makes it a model 30400041) require changing the inlet orofice on the IR burner ? I purchased conversion kit that included all new...
Did the conversion kit give you an LP orifice for every new gas valve? LP gas orifices have smaller holes than Nat gas orifices. Can you smell gas when you turn on the IR burner by itself? Some burners styles have an air adjustment on the end that fits over the orifice. Make sure it's getting enough air. Also make sure your ignitor sparker is positioned where the spark can ark against the top of the burner. Ducane grills have rotary ignitors, so turn it (with gas off) and see if you can actually see where it's sparking. If it's not sparking in the right place, it will be difficult to light.
May 14, 2010 | Ducane 30400040 Stainless Steel Grill
Ducane model number 30400040 just received set of (3) stainless tubes to replace the old ones whats the easy way to install
goto ducane web site http://www.ducane.com/manuals/
and download manual. They have Meridian and Stainless models in 3 & 5 burner for LP & NG. Follow 1 year cleaning instructions. Pictures and instructions.
Apr 05, 2010 | Ducane 30400040 Stainless Steel Grill
Cannot light new burners
I just replaced my burners and I also cleaned the starters. Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.
Jun 02, 2009 | Ducane 30400040 Stainless Steel Grill
Lighting Problem/2 year-Old Ducane Grill
Do you have enough gas pressure coming out of the regulator and gas valve? You'll need a pressure guage for this.
If yes, try taking out the burners and cleaning them with a wire brush, especially the flame spreading sections.
Sep 15, 2008 | Ducane 30400040 Stainless Steel Grill
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
Ducane 30400040 Stainless Steel Grill Logo
240 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
