Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
PDW9280N20SS Dish's are not being clean
Our previous dishwasher had no issues cleaning the dishes so the hot water to the DW is fine. We've tried using the automatic dispensing detergent option to using a package of detergent with no luck. It seems the water in the DW isn't getting hot enough.
  • GE Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 14, 2011
Water in the bottom dw smells.It's not from wet dishes dripping.It just appears every few days.Would my disposal have something to do with it?I don't know how to take it apart to find out.
try washing without dishes with a cup of vinegar or get a product at the store call dish washer cleaner that you use it in and empty dish washer to clean and remove smell.
also could be clogged strainer in the bottom of DW then need to be cleaned out!
Sep 04, 2016 | Magic Chef Dishwashers
Kenmore 13789 draining/cleaning issues
Check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher or placing large plates or pans in front of the soap dispenser. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Dec 31, 2012 | Kenmore 13789 / 13782 Dishwasher
The dish washer is spraying particles on the dishes and slime is accumulating around the edge of the bottom front of the washer-looks like hot water is not being used but it definitely is and it is...
You are probably using to much detergent. I would clean it up and cycle a LITTLE amount of bleach through it. Then I would use vinegar on a few loads instead of DW soap. See if this clears it up at all. Then use only small amount of DW soap.
Nov 04, 2010 | Maytag 24 in. MDBH950AW Built-in...
Dishes are not clean and white residue is left on dishes
clean the filters or get new ones.make sure your water in is connected to the hot water not cold.Also put new rubber O rings on the spinning arm water sockets.
Jul 20, 2010 | Maytag MDB5100A Dishwasher
My dish washer is not cleaning the dishes properly.it almost seems as if the top rack is no being clean.
try using dishwasher majic or a cleaner / ck the holes in wash arms as the must be clear . clean srreen in bottom and make sure the water tempt is hot enough .min 130 to 140 deg . low water tempt cause=s most dw washability problems . + a fresh dergt. podwer is best as liq freeze in winter and are no good. //**** .hope this helped .
Dec 23, 2009 | Tappan 18 in. MDR251RE Built-in Dishwasher
After wash cycle and rinsed cycle there were suds
Make certain you do not use dish soap when rinsing the dishes. Make sure you only use DISHWASHER soap when running the DW.
In fact,there is no need to rinse dishes. Remove visible scraps and put them in the DW. If it is a quality DW it will clean your dishes. Do not crowd the dishes in the DW. Most JennAir DW's are quality. Make sure the top rack can get washing action from the bottom spray arm. No pots or other water stopping utensils on the bottom rack.
Oct 06, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
Dish washer runs but doesn't clean? Help
This issue can be caused by:
* Water is not hot enough.
* Be sure you are using dishwasher soap recommended by the manufacturer. Also, if the dishwasher soap is old, it will not clean the dishes properly. Try with a new one.
* The pump (no the drain pump) of the dishwasher is broken, so there is not enough water pressure from the nozzles.
After checking all above the dishwasher doesn't clean properly, it may have a part broken and you may need to request repairs for the dishwasher.
Aug 30, 2009 | Kenmore Dishwashers
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
Housekeeper put dish washing soap in - machine is full of bubbles. How do I clean it out without flooding the kitchen?
Turn off the hot water supply to the DW. Take a pot or pan. Fill the DW tub with COLD water, pump it out. Repeat this COLD water and pump out several times until the suds are gone. HOT water only makes the suds worse and prevents the pump from expelling the water.
Jul 07, 2009 | Bosch Dishwashers
Dishes not dry enough & leak of water at sink vent device
HEATED DRY.Turns the drying heater on for fast drying.
ENERGY SAVER (no heat boost). Turns the drying heater off to save energy. Dishes will dry naturally over a longer period such as overnight. lf you need your dishes sooner, open the dishwasher door after the cycle is complete to reduce the natural drying time. Use of this option reduces the electrical energy used by this model approximately 7%. A rinse agent makes water flow off dishes quicker than usual. This lessens water spotting and makes drying faster, too.
Make sure inlet water temperature is correct.(SeePage6.)
Unload the bottom rack first.Water from dishes in the top rack may be spilling in to the
bottom rack.
Check for improper loading.Dishes shouldn’t nest together. Avoid overloading. Check the rinse agent dispenser to see that it’s not empty.
Inlet temperature....Good Dish washing starts with hot water, To get dishes clean and dry,you will need hot water.To help you get
water of the proper temperature, your dish washer automatically heats the water in the wash cycle. For good washing and drying , the entering water must be at least 120°E To prevent dish damage,
inlet water should not exceed 150”F. How to test water temperature: Check the water temperature inside your dishwasher with a candy or meat thermometer. Let the dishwasher run through
one fill and pump out cycle, then let the dishwasher fill with water
the second time. When you hear the water stop filling, unlatch the door and slowly open it. Measure the temperature of the water in the bottom of the tub this way: Remove the silverware basket and
place a candy or meat thermometer in the water towards the middle of the tub. If the temperature is less than 120”F,you will not get good washing results. Higher water temperature is needed to dissolve grease and activate powder detergents. If the unit is a long way from the DW you may need to let the water run in the sink until hot before starting the DW....or if is a cold day and water has not been used in a while the pipes could be cold....also if you have just used the hot water ( washer, shower...etc) give it time to recover first before using DW....All of the above mentioned material is straight out of the Users guide...but you may have an element that is going out also...so check the temp of your water and open it during the drying cycle to see if it is hot or at least warm inside...if not your element may need to be replaced...
I hope this helps...have a great day & good luck...please rate my effort.... the Fang.
Jan 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
244 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
