Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
I have a 1971 4000 tractor model #D5011f. What type of fluid does the transmission take and what is the amount. Can Iput 80w90 in it?
  • HDirkx2 May 27, 2010
    Stick shift or auto ?
Hydrostatic transmission fluid needed for bowlens tractor
The Bolens or iseki G152 will take a "TDH" fluid. The local Tractor supplier told me that as long as it says "Transmission / Hydraulic" on the container I would be OK. Most of the newer (and some older, like ours) have a single sump for the Hydraulics, differential, and Transmission and this is the product most of them use. I've been putting that in on my G152 (tx1502).
Any local tractor supply will have it. Even NAPA auto parts carries a TDH fluid. Again, whatever brand you get make sure it says "transmission / hydraulic" on the label.
Flyer
May 26, 2016 | Garden
What type if transmission fluid is used for 1988 Toyota truck 5 speed fuel injected
80w90 but have heard people putting 15w40 in it in real cold weather because the gear oil gets real thick in extremely cold temps.
Mar 28, 2014 | 1988 Toyota Pickup
Cub cadet enforcer 54 lunges
Possible transmission fluid issue. Drain, Fill, Drain, Fill.
Call dealer or check online to find which fluid it takes. It's probably 20w-50.
Look at sticker underside of tranny to fetch its model number then look it up online to see parts shematic for transmission.
Parts shematic shows the amount and type of oil.
You will have to work the axels and do the transmission purge located in your manuals first few pages then top it off its last few 8 or 10 ounces.. (unboxing)
Possible carb dirty.
Jun 13, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
Wath is the correct oil of automatic transmission sentra SE-L 1999
Dextron II is approved for Nissan as a suitable replacement for Nissan's own Type J transmission fluid.
Jun 04, 2011 | 1999 Nissan Sentra
Checking fluid level
most units of this size & quality have a factory sealed transmission. to check or change oil, the transmission would have to be removed.
Sep 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to know what kind of aouto matic drive fluid
Most units are sealed and do not require adding fluid. Normall 20w50 engine oil is used. Consult your owners manual or sears.com for confirmation.
May 17, 2009 | Garden
Need to know all fluids types
Engine oil 10W30
Transmission Mercon
Front Differential 75W90
Rear Differential 80W90 (if changing I would recommend going to 75W140 sythethic)
Transfer Case: Mercon
Brake fluid DOT 3 or 4
Coolant: Regular Green
Dec 03, 2008 | 1995 Ford F250
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
233 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
