Question about Maytag 22.7 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black
My maytag refrigerator is not cooling at its highest set point
I have a maytag refrigerator and I found all my meats and a bag of ice thawed in the morning. I set it to the highest set point and Still don't work. the Compressor sound like is working and I feel air flowing but is not cold. Can anyone tell me what the problem is.
  • Maytag Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerMy maytag refrigerator is not cooling at its highe - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 27, 2010
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
Sep 28, 2014 | Maytag 20 cu. ft. Upright Freezer MQU2056B
The refrigerator is not cooling. the freezer is working well all lights are on but no cool air is coming from the bac air vent What do I do???????????? Maytag MFT2771WEM
check the refrigerator temperature controller and set it to the highest number. If it still does not solve your problem then In my opinion too much ice has formed in freezer block and is blocking the way of cool air from freezer compartment to refrigerator compartment. Just shut off the whole refrigerator for one day and leave the door open to melt the ice and then put it on next day to see whether it can solve your problem.
Sep 01, 2014 | Maytag Refrigerators
Ice maker not making ice
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
18 cu inch refrigerator ge hotpoint
my freezer is set higest and meats frozen ice cream soft the refrigator part is set on #9 but everything is not warm but just a little cool
Jun 16, 2008 | GE GTH18JBR Top Freezer Refrigerator
Maytag LRTC15A AH01A - not keeping insides cool - condensor fan working and clean - freezer fan working - cannot feel air flow to crisper (meat bin).
The flow ducts from the freezer to the lower part were frozen solid. Once fridge thawed and drained, all worked fine again. Flow duct very hard to get at.
May 13, 2008 | Maytag Refrigerators
Kitchen Aid Fridge
no ice in freezer section??? not able to keep meat frozen , is it making ice??? sounds like a compressor issuew and not covered by manufacture warr is generally not a worthwhile repair
Mar 02, 2008 | Frigidaire FRT21HS6D Top Freezer...
Right side of refrigerator not cooling; frezzer working great
The coil is the thermostat that controls the damper which allows more or less cold air into the fridge compartment and should be put back as you found it. Very important. The problem is that the freezer is not defrosting, hence the ice build-up on the back wall. Either the defrost timer is faulty or the defrost heater is blown. There are two thermostats behind the freezer panel, one in line with the fan and one in line with the heater and they will be clamped to the pipework. Both these thermostats should be closed when iced up. If the fan is not running, that could be faulty too or its thermostat.
Nov 02, 2007 | Maytag MZD2752G Side by Side Refrigerator
Maytag 22.7 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black Logo
112 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
