Question about Kenmore 24902 Top Load Washer
When machine is running it makes a squealling sound
Why would my washer suddenly start making a squealing sound when it is running?
  • oldguy5 May 11, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since top load and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem. Does the problem occur during the agitate or spin cycles??? Can you smell anything unusual (like burning rubber)???? Have you tried it on a different cycle???
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
The most likely and easiest thing to check is the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning AND will likely make a squealing noise if its' wearing.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Apr 26, 2010
My washer makes a loud squealing noise when it spins, what is wrong
Hello Kathy McAlister - Typically, when the washer is making or produces a squealing sound is due to an overloaded load. I recommend running a cycle with less clothing. If issue continues, then consult with a professional to accurately pinpoint any potentially more serious issue like a faulty belt or a bearing/pulley suspension problem. The washer could possibly have broken something off in between the tub and outer portion of the unit.
Feb 23, 2013 | Frigidaire FEX831CS Top Load Stacked...
Toyota Siena squealls when car starts & really bad
Do you know how old the assy drive belt is?
There other item would be the blower under the dash
Should be easy to separate those sounds
Sep 10, 2012 | Cars & Trucks
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
MAV408DAWK Maytag top load washer is squealling
The noise could be coming from the wornout drum bearings. It needs replacement.
Oct 13, 2009 | Washing Machines
Loud squealing
sounds like shims on brakes, or lack of them
thin bits of metal to stop squeel
Jul 08, 2009 | 1997 Chevrolet Blazer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Squealling during cold start
yes and cheak power stering belt and fluids ok
Oct 06, 2008 | 2004 Kia Spectra
Washer spinning
Hi jmm119
Its hard to say what it is but it could be one of 2 things, either the belt ore the main bearing is gone. but my first guesss would be the belt.
brent
Sep 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Loud noise
sounds like the absence of lubrication in the transmission. could be a bad bearing on the pulley side
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Kenmore 24902 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
