Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Sparkplug gap for poulan chainsaw model 2025 - Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
    President:
  • 2,030 Answers
.030 -.045
Posted on Apr 25, 2010
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
Gap coil on ppb 330 poulan pro
First and foremost ppb330 is a model number for a grass line trimmer, gas model.
Second, I am unsure what you are asking. Gap coil?? Do you need the spark plug gap for your chainsaw? That gap is .025.
I hope this helps. If not, please re-post with the correct model number for you chainsaw.
Jul 08, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the spark gap for 221 pro 40cc
The gap for all Poulan chainsaws, regardless of the spark plug used, is .025.
Jun 12, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What spark plug (make, number) can I get for a Poulan 2025 chainsaw and what gap?
Replace with Champion CJ-7Y or RCJ--7Y spark
plug and tighten securely with a 3/4 inch
socket wrench. Spark plug gap should be
0.025 inches
R stands for resistor on the RCJ-7Y. Either plug will work.
PDF of Owners Manual
If you have other questions about your saw, there is an 800# at the top of PDF.
Hope this helps.
Oct 21, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I Have a Poulin chainsaw with spark and gas. The spark is not as strong as it shoud be, hence I can turn the motor over holding the sparkplug in my hand and feel very little charge from it. I have tried...
I think you should check the gap setting on the magneto and make sure it isclean. Replace mag if output is still weak. Also check all wiring connections to make sure they are clean and tight.
I'm sorry but I don't have many manuals for poulan and you didn't say what model number it is. If you have owners manual it should tell you what the gap is. Good luck and thank you.
Jun 20, 2011 | Poulan Garden
What is the sparkplug gap
On most applications it is .020. You can use the tip of a flat head screwdriver to make sure the gap is not too small.
Mar 31, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need to replace fuel lines. routing of lines on Poulan chainsaw Model #2025 with 16" bar
A Poulan 2025 IPL follows:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://www.ordertree.com/modelinfo/PWE/2025-Gas-Saw/75.2025-Gas-Saw.1.59.1.html
Small hose (filter on bottom) long enough to reach all corners inside tank, to lower carburetor connection. Please leave the 2 carburetor connections long enough to reverse until the saw is running.
Upper carburetor connection, small hose to suction side of primer.
Pressure side of primer (large hose) to middle of tank. nothing on bottom, length not critical.
The IPL is deceptive it appears the filtered hose connects to the primer; it does not.
Typical fuel system link and a couple of suggestions here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 16, 2010 | Poulan Garden
I NEED TO KNOW THE SPARK PLUG GAP AND MAGNITO GAP FOR A POLAN CHAINSAW MODEL # 2375
Spark plug gap is .025
As for the air gap in-between the flywheel, and magneto, I generally start with a piece of notebook paper in-between them.
After the bolts are snugged down, turn the flywheel by hand to spin the paper out.
Oct 29, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
411 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
