Question about Samsung HP-T4254 42 in. Plasma Television
When this tv was turned on, it crackled and popped. now no picture
YOUR POWER SUPPLY MAYBE DEFECTIVE BLOWN CAPS BRING TO REPAIR CENTER
Posted on Apr 29, 2010
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
Sony rear proj; kdf 55
If there is no picture but sound is audible then replacing the projection lamp will do otherwise, the TV requires to be diagnosed for any other hardware damages.
Aug 27, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV makes "Pops" and "Crackles" sounds from the back while viewing
remove the cover and observe the source of the light. if its in the picture tube it can be fixed with a picture rejuvonator. if its a cracked solder joint a soldering iron and solder will fix it.
Dec 06, 2008 | Philips Magnavox 42MF521D/37 Television
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Loud pop/crackle and now picture is marbled...
The picture being displayed might just be the 480p resolution and it looks faded at times.
Aug 19, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Sanyo 32" television
If the picture is OK with DVD and VCR, then perhaps the problem lies elsewhere other than the TV. It could either be your:
1. aerial antenna or
2. cable connection.
Aerials can re re-oriented/realigned to improve reception or reduce interference while the cable would require that you get in touch with your cable provider. In some instances cable problems could be loose connector at the back of the TV. Additionally, interference can be caused by other electrical/electronic devices. Past experience has shown me that even a 2-Stroke lawn mover/grass cutter has these effects.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 24, 2008 | Televison & Video
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Samsung HP-T4254 42 in. Plasma Television Logo
96 people viewed this question
Henry  Thomas
Henry Thomas
