Question about Culligan Sediment Water Filter
Stange noise coming from reverse osmosis system
Sounds like the valve is rusty and in pain...the system has been well maintained, was working fine a few day's ago and now this strange noise emiting, sometimes the noise is intermitant and sometime - like right now - it 'beeps' every second.
I shut all the valves leading to it last night and that seemed to stop it but now...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
The sound you are hearing is from the ASO (automatic shutoff) on the back of the housing, above the membrane (center filter). It has a diaphram and spring that can weaken. It is trying to close but can not close fully. This will cause a squeal or chirping sound. The ASO shuts the water off to the RO system when the RO tank fills up and pressure equalizes across the RO. The ASO can be taken apart and cleaned/serviced. If it is time to change the filters (every 6 months, pre and post filters) I would have the system sanitized and the ASO repaired. Have the capillary tube replaced as well.
RJ
Posted on May 21, 2011
Culligan AC-30 Howling Noise
yes you answered your questions there. i researched info and more than likely it is the valve
http://watersoftenernews.blogspot.com/2014/02/culligan-water-softener-noise.html
Oct 13, 2014 | Culligan RO Compatible AC30 Compatible...
Reverse Osmosis Noise AC30
Take the system back apart just like you did to replace the filters and put them back, only this time do it correctly.
Jul 23, 2012 | Tools & Hardware - Others
Water coming from the hot water valve (so right off of the boiler) is cloudy, almost rusty colored. We just had our water changed to a new reverse osmosis system, but were using reverse osmosis water...
The boiler is contaminated if the smells funny, if not then the water is leeching the minerals out of the boiler. RO water is an acid (pure water), it is just as bad as distilled water for espresso machines.
Mar 07, 2011 | Astoria Argenta SAE-2 Espresso Machine
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
Refrig Model # FRS26ZRG Ice maker is connected to a reverse osmosis. Has 60 lbs. psi. Was working fine now i hear the switch it sounds the same only no water comes into trays. also no water at door but it...
1. Check the water line to be sure it's clear, unobstructed and that water is available (check your RO unit too)
2. Check the water filter
3. Check the water valve
Visit this site for more info and diagrams - www.appliancepartspros.com
Put in your fridge's exact model and examine the parts lists.
Aug 21, 2010 | Frigidaire Refrigerators
What line do you tap into to add an icemaker to a GE Reverse Osmosis water system?
If you want the reverse osmosis water to go to the ice maker then you tap in to the line that feeds the spiget on the sink.
Mar 03, 2010 | General Electric Profile Smartwater Ultra...
I bought a new tank for my reverse osmosis water treatment and it did not come with directions. It's supposed to be ''charged,'' whatever that means. When I hook it up to my system it does not fill with...
Typically a reverse osmosis storage tank should have a precharge of approximately 7 psi. Depending on the make/model of your tank it may have a higher charge currently which would cause the tank to not fill. There should be a schrader valve on the bottom or side of the tank. Using a tire gauge and bicycle pump you should be able to check the current pressure in the tank and adjust it up or down to 7 psi.
reverse osmosis storage tanks: http://www.freshwatersystems.com/c-32-reverse-osmosis-storage-tanks.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Nov 04, 2009 | General Electric FX18M GE SmartWater...
My whirlpool ed27dqx refridgerator quit making ice immediately after I had my reverse osmosis drinking water system upgraded. I replaced the ice maker unit and the dual water valve. I have always had water...
The pressure from a reverse osmosis system is not sufficient to operate the ice maker water valve. A water valve requires a minimum of 20 pounds of pressure without a refrigerator water filter, and 35 pounds of pounds of pressure with a refrigerator water filter. Manufactures do dot recommend installing an R/O system on the water supply to a refrigerator. The pressure may have been higher from your old system.
Apr 28, 2009 | Refrigerators
I am getting slimy film floatys in water from my reverse osmosis system. I just changed the sediment and activated carbon filters.
When you replaced the cartridge did you by chance clean out the unit before putting in the new one? If not, then this is where it is coming from. I would suggest that you take it apart again and make sure that it is clean inside. This slime build up in the filter is completely normal and may also indicate you waited a little too long to replace. It also depends on the type of water you have as well.
Apr 10, 2009 | Dmm Designer Water Filter Reverse Osmosis...
Culligan Sediment Water Filter Logo
897 people viewed this question
Top Culligan Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Culligan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
