Question about Brother LS-1217 Mechanical Sewing Machine
Tension When I sew The Line at the top is sewing corectly and when I turn the fabric over Its all jumbled up! I bought a new bobbin and it still didnt work, so now I think the tension is messed up and I dont know how to fix it.
    Genius:
  • 1,116 Answers
Turn off the power, open the throat plate. Raise the needle to the highest position and remove the bobbin case. Clean the area and replace the bobbin case and throat plate.
Thread the machine with the presser foot up to see if this will eliminate the looping stitching.
Be sure to use the correct size needle for the type and weight of the fabric being sewn. There should be a chart in the manual for the machine. There should also be a suggested setting for the tension.
If you need a manual, check the Brother website for a download.
Posted on Apr 25, 2010
I can't get the tension right on my Janome DKS30 sewing machine. I can operate a machine but I am quite a novice. My machine is 9 months old and I have used it less than 20 times. Can you please help?
Sounds like your top tension is too tight. You may find it helpful to join a FaceBook sewing machines group to get further help. Happy Sewing!
Dec 30, 2016 | Janome Sewing Machines
Upside down stitching
Am having a difficult time picturing this. Sounds like the upper thread is creating loops under the fabric and the bobbin thread is showing on the top of the fabric.
Make sure to use a brand new needle.
Remove the thread from the machine
ALWAYS raise the presser foot and rethread the upper thread.
Make sure the thread path is correct.
Check that the bobbin is turning the correct direction in the bobbin case and the bobbin thread is threaded through the bobbin tension correctly.
Set the upper tension to the midway point (factory standard), however, this setting may need to be tweaked for your particular machine.
Bring the bobbin to the top of the project Before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Retest--begin sewing slowly.
If the upper thread is still showing on the other side of the fabric, the tension is too loose. If it is pulling the bobbin thread up to the top of the fabric, the upper tension is too tight
OR the bobbin thread tension is too loose. (CAUTION: make only small adjustments to bobbin tension--1/8 of a turn at a time!!! It also helps to mark the screw groove location with magic marker on the bobbin case BEFORE making any changes so you can back it out and return to the original setting.)
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 05, 2016 | Sewing Machines
Straight stitch. Top is fine loose on bottomadjusting top tension does not help how to adjust bottom tension?
Usually, if there are loose threads under the fabric, it is the top thread that is too loose. Check your sewing sample closely--you can even test with two different color threads to help distinguish which thread is which. Loose top thread will generally be pulled DOWN and show under the fabric. Loose bobbin thread will be pulled UP and show on the top of the fabric. The ideal tension is when both threads MEET in the middle of the fabric.
First, remove the thread from the machine. Install a brand new needle. Always Raise the Presser Foot and thread the upper thread, making certain the thread path is correct.
Check that the bobbin thread is threaded correctly and turning the proper direction in the bobbin case.
Set the upper tension to the midway point and sew a retest. A tweaking of upper tension may be necessary to get it where it should be. Generally, upper tension should make the majority of adjustments needed for tension correction. Bobbin tension is one of the last tension adjustments to make as it is very sensitive and can go awry very quickly.
If, in fact, the bobbin tension is off, the tension skrew on the bobbin case is where the adjustment is made. Before making any bobbin tension adjustments, mark where the skrew slot is located on the bobbin case with a permanent marker. This will allow you to reverse your changes if necessary. Be CAREFUL as TINY changes make HUGE differences in tension. Make only 1/8th turn adjustment, then retest before making another adjustment.
Remember that tension testing and readjustment are a necessity when sewing. The same tension that will work with light weight thread and fine fabric will most likely not work when using heavy thread on drapery fabric. Get comfortable with making tension adjustments to get the ideal tension for each project.
Oh You Crafty Gal Sewing Lesson 10 How to Fix Tension on Your Sewing...
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=14&ved=0ahUKEwilg-3t2vHMAhVJDlIKHXnsBWYQFgheMA0&url=http%3A%2F%2Fwww.ca.uky.edu%2FHES%2Ffcs%2FFACTSHTS%2FCT-MMB-213.pdf&usg=AFQjCNE4QlGk1Fvt8K2UGCRCfzMpGS-A2Q&cad=rja
How to Adjust the Tension on Sewing Machine
May 24, 2016 | Sewing Machines
How do I fix a bobbin tnesion problem>
Bobbin tension is one of the biggest problems most sewing machine operators have. Check information sent for assistance on this.
Jul 23, 2015 | Sewing Machines
Toyota quiltmaster
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the top.
Be sure that your top thread follows the correct thread path.
Set the top tension to the midway point.
Re-test your machine.
Tension is a tug-of-war between the top and bobbin threads. Correct tension is when both threads meet in the middle of the fabric. If the bobbin thread is laying on the underside of the fabric, the top tension needs to be increased so it will pull the bobbin thread up into the fabric. If the top thread is pulling the bobbin thread up to the top of the fabric, then the top tension needs to be loosened.
TIPS:
FWIW, thread tension is not static. Tension will need to be adjusted probably every time you start a new project. Test it on a piece of scrap fabric from the project and adjust it BEFORE beginning the project. Remember to change the needle often--probably every time a new project is started or every 8 hours of sewing time. Be sure to use the correct type and size needle based on the fabric & thread you are sewing. Also, AVOID old or bargain bin thread!
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
All About Needles SCHMETZ Needles
Nov 24, 2017 | Sewing Machines
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
here is a free manual
http://www.singerco.com/uploads/download/696_5417c.pdf
Jan 07, 2013 | Singer 5417 Mechanical Sewing Machine
Top tension has to be turned all the way down to get good stitch, then thread gets caught in bobbin and lower hooping on thread..
Grab some scrap fabric of the same type you'll be sewing. Tighten your top tension and test sew until you see until you see the top thread of a seam go like a straight line and the bobbin thread loops on top of the seam. Then back off of the top tension until those loops disappear.
If you never see it the top thread go like a straight line... your top tension needs to be cleaned... and make sure you have the pressure foot UP when you thread the upper thread.
Aug 03, 2012 | Sewing Machines
Top thread is fine bottom thread all jumbled
I've had the same problem - jumbled threads on the underneath side of fabric. My solution was this: I had recently purchased new bobbins and they turned out to be the wrong size. I went back to the ones that came with the machine and the problem disappeared. So, have you recently purchased new bobbins? They might not be the correct ones. Funny, in all of the posted possible solutions below, not one mentioned this possibility. turns out my new ones were not as tall and were slightly concave instead of taller and flat. Check your machine manual for the correct bobbin part number.
Nov 23, 2011 | White Sewing 2037 Mechanical Sewing...
My singer sewing machine model # 774 will not produce a lower stich that is not all jumbled on the underside of the fabric. The upper stich is fine, it's the bobbin stich that comes out all jumbled. ...
Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 08, 2011 | Sewing Machines
Brother LS-1217 Mechanical Sewing Machine Logo
669 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
