Wireless problem I have a Acer laptop and whenever i bring my laptop home from the office it will not connect to my wireless network at home at all. When i click onto my wireless connections configuration screen it comes up with "windows cannot configure this connection....." I have tried running services.msc (as suggested on the microsoft website) but this seems to do nothing at all. I am now at home for 2 weeks and have no wireless connection which is a real pain. Everything connects ok through the lan connection its only the wireless that won't connect. Help someone please !!!!!!!!!!!!!
Uninstall the wireless configuration utility and install drivers only for wireless adapter then you can use windows own wireless config screen
Posted on Jun 30, 2008
    Genius:
  • 3,587 Answers
That's because your windows wireless is most likely conflicting with the actual wireless device manager..only one can do the job..
Posted on Mar 23, 2008
Don't know how to connect to my home wifi
Connecting your Acer laptop to your home wireless network is fairly simple.
Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position.
Not all models have this switch.
Open the Windows Start menu and select "Connect To."
A list of available connections will appear.
Select "All" from the drop-down menu to view all available networks and connections within range.
Select the desired network and click "Connect."
Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Mar 11, 2014 | Acer TravelMate 2480-2779 Notebook
How can I get my acer aspire one mini laptop to access wifi?
Connecting your Acer laptop to your home wireless network is fairly simple. Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position. Not all models have this switch. Open the Windows Start menu and select "Connect To." A list of available connections will appear. Select "All" from the drop-down menu to view all available networks and connections within range. Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
Wireless configuration for your laptop http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Feb 21, 2013 | Acer Aspire One AOA150-1949 Laptop
Hello, I recently purchased a new laptop (Sony Vaio, E-Series, VPCEB36FA). Whenever I try to connect this laptop to my home wireless network provided by a 6200 ADSL2+ 4-Port Zhone Router, it never gets...
Seems you forgot everything.
1. You could try the default username : admin with password : admin or username : user with password : user
2. if those not working you can reset your ADSL modem to the factory reset by push the "reset to default button" in the back panel, this will bring your modem to the very first time condition. Use the method 1 to login.
cheers
Feb 10, 2011 | Zhone (6218-I2-200) Router
I can not figure out how to get the computer to make a wireless connection.
Add the Home SSID to the Preferred Network List After you set the SSID on your home gateway, you may need to add it to your preferred network list if Windows XP Wireless Auto Configuration is enabled. (Although automatic configuration is nice to have, your IT department may have disabled it on your laptop in order to meet their needs. If they have, you'll need to use the tool provided by your laptop or wireless manufacturer to manually configure wireless settings.) To manually add your home wireless network to the list of preferred networks when Wireless Auto Configuration is enabled, follow these steps:
• In Control Panel, click Network and Internet Connections, and then click Network Connections.
• Right-click the Wireless Network Connection, and then click Properties.
• On the Wireless Networks tab, shown in Figure 3, click Add.
Figure 3
• In the Wireless network properties dialog box, shown in Figure 4, enter the SSID you configured for your wireless gateway (ExampleHome_g in this example.)
Figure 4
Note: Figure 4 assumes you've added the Windows WPA Client Update. If you haven't downloaded and installed it, you probably should. For more on the WPA Client Update, see Overview of the WPA Wireless Security Update in Window XP.
• Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway.
• Click OK and your home network will be added to the list of preferred networks.
Now, whenever you're at home, your work laptop should automatically see your home wireless network and connect to it.
Jul 05, 2010 | Acer Aspire 5100 Notebook
Only 1 computer connects wirelessly
Possibly you have to tell the laptops to connect manually - if you look at your wireless networks you should see your router listed and there should be a connect button - usually once a network is connected manually it "remembers" and connects automatically the next time. That can also usually be set in the properties for the connection to do auto connect. It all depends on the settings each PC has to allow connections.
Oct 25, 2009 | Belkin (F5D7050) 802.11a/g/b Wireless...
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
I want to connect at home
Around the office, your laptop is probably connected to a wireless network which you don't have at home. To connect, you would need to connect to the office network from your home through a VPN (Virtual Private Network) over the Internet or through a dial-up (ugh!) connection to the office systems. Your office IT staff should be able to help you get that set up since either way it would require some configuration on their end to allow you to connect remotely to the office systems.
Apr 18, 2009 | Dell Latitude D600 Notebook
My wireless wont connect to home, and it shows a big red ''X'' whenever i try. It says that the setting are different, I changed NOTHING and it worked last week.
I'll assume you're using Windows Wireless:
Right click on the taskbar icon + view available wireless networks + change order of preferred networks + delete you network from the list + add network + manually enter the SSID and the security key + ok and exit.
Post your results back here...
Mar 03, 2009 | Acer Aspire 5520-5156 Laptop
Setting up wireless internet connection , my new acer laptop
hi there i have a problem connecting my new acer laptop to the internet..I've tried your suggestion but i can't still connect to the internet..can u help me to connect my new laptop to the internet? is there a program or a disk for me to open the internet connection of my laptop...thanks a lot and i hope u will help me
Jul 11, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
619 people viewed this question
David Payne
David Payne
