Question about Vizio VR3 Remote Control
Remote only works ar close range. same for cable or vizio remote.
  • Anonymous Mar 17, 2014
    my vizio [2] remotes will not work anymore.. model numbers are [ e261va ] and i have a bigger tv model number is [ e470vle ] this remote works on the small tv's.. so my question is , should i buy 2 remotes with the model number [ e470vle ] for 2 tv's with the remotes [e261va] that don't work???
    Genius:
  • 1,274 Answers
Try fresh batteries,and clean the senser in front of remote with damp rag.....hope this was helpful...
Posted on Apr 25, 2010
Vizio will not power on, vizio emblem is off.
Did you check the power cord of intermittent connection.
Mar 29, 2014 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
Vizio vl370m remote control
If remotes have been ruled out the only way to test the remote infrared receiver is with the set apart/ and a schematic measure voltage at the receiver when the remote is used---most of the time since the part is rather small this is just replaced to see if it is or is not the problem; some receivers will fail where if the remote is held very close they work--always the receiver in that case.
Apr 12, 2012 | Vizio VL370M LCD TV
Purchased and set up both Vizio SV370XVT HDTV and
Try setting your cable box for Closed Captioning. Worked for me.
Jan 21, 2010 | Vizio VX37L Television
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
Jun 02, 2009 | Vizio VX37L Television
I have a Vizio GV42L LCD HDTV. The remote no longer is able to work the TV until it is moved closer tothe unit. I have tried another remote from my cable compnay that could work the TV but I get the ame...
On the front bottom of the TV there is a little round eye. If that eye gets blocked, it'll reduce the range of the remote. Make sure there's nothing in front of it. Other than that, the sensor behind the eye could be bad.
Hope that helps...
Geno
Apr 02, 2008 | Vizio GV42L 42 in. LCD Television
Verizon remote won't work
I am a Verizon tech and the remotes we use work for Vizio sets just fine. If for some reason the remote wont work and he tried 3 different ones then it has to be your set. I set FIOS up all day and have no trouble with those TVs
Mar 09, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio codes for cable remote control
I don't have any trouble getting my directv remote to run my Vizio. I can't get my Vizio remote to run my directv hd dvr receiver. The Vizio remote is way cooler. I would rather use that one. Can anyone help?
Feb 05, 2008 | Televison & Video
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Vizio VR3 Remote Control Logo
387 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
