Question about Zanussi FJD1666W Front Load Washer
Tumble dryer works for 10 mins then switches off and flashes E20....what does this mean?
  • 269 Answers
E20 relates to a blockage in the pump check the filter and that the pump is free to turn there may also be aproblem on the drain pipe check this also
Posted on May 04, 2010
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Tumble dryer not heating - White Goods Help
Nov 28, 2015 | Candy Dryers
What does e24 error on my siemens tumble dryer mean ? After about 10 mins the machine make an alert warning noise and flashes the error sign and said turn off and start again .
Unfortunately, it means you have a computerized machine that can only be repaired by a technician with proper diagnosing equipment. Even if you can find out the meaning of the code... that may not tell you what to do about it. (It usually involves replacing circuit boards). Monetarily, with regard to cost of repairs, we were all far better off back in the days of ''switches'', ''knobs'' and ''mechanical timers''.
Sep 01, 2014 | Siemens WT46W568GB Condenser Tumble Dryer,...
Aeg tumble dryer e20 error code won't start
E20 is a master code for two sub-codes E21 and E22, both of which need taking a look at the electronic board. Best to call the service engineer.
Jun 28, 2014 | Washing Machines
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Zanussi washer dryer showing e20 error message in dryig cycle
Hi
This means that the filter is clogged. Unscrew the filter it'll be full of lint. E20 also means drain problem. If it actually goes through the Spin cycle then there is most likely some water still not drained out at the time of the tumble dry. Check the drain and the hose to make sure it isn't clogged.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 03, 2011 | Zanussi Washing Machines
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
Zanussi washer/dryer zwd1471s
E20 normally means there is a blockage in the drain tube/filter. I have the same problem, but the drain tube is clear. I have searched the web and found the solution being down to the "plastic bottle-like condensor having debris/fluff in it".
Nov 30, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi
E20 = Problems with water drain in wash phase ALARM CODES E20 Is the drain filter clean; Problems during draining phase (Machine tries to drain for 10 min without emptying the tub) Checks to do: E20 Is the drain pump working? Is the value of the pump about 200Ω? (Measure directly the connector by the board, between J2-2 and J2-7) ; If No Change the pump and run again Clean the filter; Is the draining system OK (drain hose and plumbing where machine is connected) Free and check the draining system; Is the pump blocked? Is there any burn mark on the control board; if yes Change the board E90 = Communication error between user interface and main board. Verify the connector between the main board and user interface board by plugging and unplugging the connector few times on both sides, OR replace the blue ribbon cable. The fault could have been caused by oxidized contacts in user interface plugged in the main board. Kind Regards David Marsh
Jun 19, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FJD1666W Front Load Washer Logo
104 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
