Question about Philips Magnavox 27MS343S 27" TV
Snow on the Tv screen
We have a dehumidifer in our crawl space and when it comes on snow comes on the tv screen and degrades the vewing experience...is there
a device that can be purchased to eliminate this problem
  • 74 Answers
Make sure the dehumidifer is grounded with a 3 pin plug, into a 3 pin recepticle. If so, try plugging the dehumidifer or the TV into another power outlet.
Posted on Mar 24, 2008
Snow on screen
If blue-back option is OFF, it is normal to see snow on screen, when there is no RF signal. This is not a fault.
Aug 04, 2012 | Sharp 25J-S100 25" TV
I have a pincushion problem on the screen , what causes this and how can it be fix?
Not sure what a pincushion problem is? If you mean it pixalates and/or seizes up, runs, you may need to re-peak the dish signal by repointing it, reinstall the dish, if trees or something else is partly blocking signal to the dish. Some transponders on the satellites are much weaker than others. Check signal on the transponder you have the most problems, go to install satellite to check signal. Even rain and snow on the dish or in the air can degrade the picture. Another problem can be caused by used old cable tv wire to bring signal in for the dish. Newer receivers require much more bandwidth that requires good quality RG6 cable coax wire. Even roosting birds can cause problems.. Make sure there is no snow on the dish.
Feb 11, 2011 | RCA Televison & Video
What can I do to fix the flipping of the screen from snow to prog
the tuner is getting a weak signal and that is why the vertical sync signal is weak and the picture is rolling .check the cable on the back
May 23, 2009 | Samsung Televison & Video
My tv get snow when i try to play a game
Try using another TV. If you don't get the same problem then it's the TV and not the PS3. You might also want to try changing the display settings so that you're using the correct outputs.
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
Snow Across the screen
just check the antenna wire or the coaxial cord
Oct 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dehumidifer Initial Purchase
You may get a better effect if you ventilated the crawl space.
Jun 05, 2008 | Goldstar DH504EL Dehumidifier
My big screen tv show snow on all channels.
ok.
if you see only snow on the regular screen, might as well check the connecting antenna at the back since you mean all snow on all channels.
hope this helps.
Jan 17, 2008 | Akai PT4298HD Rear Projection Television
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Sep 27, 2007 | Toshiba TP50H50 50" Rear Projection...
Picture problem when I use an external antennae
You cant unless you have been trained to trouble shoot solid state electronics as this set has no user serviceable parts inside and is best left to the pro tech to service. good Luck
Aug 08, 2006 | RCA F27645 27" TV
Philips Magnavox 27MS343S 27" TV Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
