Question about Husqvarna 28cc Gas Line Trimmer
326rjx bogs down when you pull the trigger .cleaned air filter and spark plug new gas and oil mix what do you think?
  • 54 Answers
Sounds to me that your high speed needs adjustment. Usually by turning it slightly out will take care of this but don't turn it so far that you lose quick throttle response.
Posted on Apr 26, 2010
What causes it to stall when trigger pulled?
Generally lack of fuel..
Pulling on the trigger doesn't increase the fuel getting into the engine like you'd think. The trigger opens up a butterfly valve which allows more air to be drawn in, this in turn draws more fuel through the carb. So if its bogging down when the throttle is pulled then generally it because not enough fuel is being drawn through b the air.. meaning there's too much air to fuel mix to burn effectively. This also can work the other way if the air filter is blocked or the exhaust is blocked with carbon deposits.
Mar 15, 2016 | Garden
Saw will not rev up to full rpm when you pull trigger it revs up to 1/2 to 3/4 throttle and starts cutting out.
Engine may be too worn or may have run out of oil at some point, compromising the bearings.
May 13, 2015 | Garden
I can't get my blower to accelerate. It will only idol on full choke. If you pull trigger it bogs down. I replaced the fuel line and sprayed carb out.
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the Fuel Tank
  • Spark Plug
  • Spark Arrestor - at muffler
  • Carburetor - May need a rebuild kit
Watch this as well...
and...
Oct 18, 2013 | Stihl Bg 55
I mixed correct oil,gas, but still runs bad,acts like wants to bog out
Plugged air filter or exhaust,maybe?
Fuel restriction?
Nov 12, 2012 | Garden
80 suzuki dirt bike giving the gas it bogs down cant figure this one out
There is many options to cause this, spark plug failing, dirty carbi, but the most common cause for this would be fuel mix itself (what fuel ratio are you using?) Try decreasing the oil in your fuel mix slightly see if this improves then move to carbi inspection / full clean and new spark plug
regards jamie
Aug 16, 2011 | Suzuki RM 85 Motorcycles
My husqy 435 runs but skips and bogs when you give it gas! spark plug is good, air filter is clean. could it be the ignition pack?
It could be the ignition module, but if since it is firing I would say it is a bad fuel filter. Try replacing it. Also, try using fresh gas. Mix a 50/50 gas to engine oil mixture and put that in.
Nov 14, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Starts but won't stay running, i clean carburator and still have same problem, unit has been used very little, still look new, Thanks,
Have you checked your oil? You need pump oil half way up in reservoir. Open plug on top of pump and check oil. Pump takes SAE 20 or 30
Next, open oil plug below engine and check your oil level. It should come up 1/2 way on dip stick. Engine takes 10W30. Don't turn washer on its side or upside down to drain oil or oil will run into carburetor.
Is the water turned on? Are you holding gun trigger open while starting? Pump needs water flow. DO NOT tie gun trigger open with wire and then start engine. That gun will flip around and shoot a hole in your leg.
If the engine starts, then you have gas, spark and compression
If engine won't stay running, the exhaust port might be clogged, or the carburetor is not letting in enough gas, or gas is not flowing to carburetor.
Check the screen over exhaust port > is it dirty or clogged? Clean with WD-40 or break it out with a screwdriver.
Remove gas filter below gas tank >>> it has a hex bolt >> loosen bolt >> the gas should come flowing out >> put it back if gas comes out
Next remove rubber gas line feeding gas to carburetor >> gas should flow out this line too >> if flows then put it back.
What about your air filter? Take it off. See if engine fires and runs without air filter. Air filter may be clogged.
While air filter is out, you can see open port to carburetor. Spray some WD-40 into carburetor. Fire up the engine. It should spark real healthy on the WD-40. Keep spraying WD-40 into carburetor to see if you can keep engine going. Don't forget to keep gun trigger open so water is flowing and pressure is not building in pump.
If engine keeps going with WD-40 but dies without it, then your carburetor is very suspect. You might need a new one.
If engine will not keep going with WD-40, then the spark is very suspect.
Change spark plug. Try again. If it doesn't fire up after that, you need to take it to the shop for repair.
Oct 09, 2010 | Honda 2500 PSI Gas Pressure Washer
My tanaka chain saw wont idle and when i pull the gas trigger it quits or bogs down
clean spark plug and gap, remove air filter and clean, look at the spark plug and tell us what color it is, You may need to adjust the fuel mis to get it to run right or you may need a gas filter. Post here with more information.
Aug 28, 2009 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Ryobi BC 30 trimmer bogs down with throttle
some have to warm up, although there should be a gas/oil mix screw on the carb try adjusting it
May 07, 2009 | Ryobi Garden
Bike bogged down like plug fouled now wont start
Based on the information given, I think you may have a hole in the top of the piston. It sounds like pre-ignition, ( AKA detonation and engine knock ). Pull the cylinder head and check the piston and cylinder head. Sometimes the top outer edge of the piston disintegrates due to the heat. Replace the piston and rings and remove the carbon from the head. Be sure you run 32/1 mix on gas and oil. That's 4oz two stroke oil per gallon of gas. Only use premium gas.
Remove and clean the carb. Be sure the carb mount bolts and carb manifold bolts are tight. An air leak will cause the engine to run hot.
Please rate this solution. Thanks
Apr 06, 2009 | 2003 Honda CR 125 R
Husqvarna 28cc Gas Line Trimmer Logo
303 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
