I have not used my printer for several days; I have turned it off for 60 sec. I have changed it from my default printer and back to default printer, but it is still offline and I don't know how to get it back online so I can print
  • 369 Answers
1. First of all check if your printer is connected to the computer and powered on. 2. Now, click Start, click Control Panel. Click Printers. Find your printer. Right click it and click Online. 3. If this does not work, turn off the printer. Disconnect all of the printer cables from the printer and computer both. Disconnect the power cable from both of the ends. Now, turn off the computer. Connect all of the cables back in and restart the printer. Now, restart the computer and check. 4.Again follow the steps given under step 2. 5.Also try to print using the printer console. If it does not print, then it is an issue with printer and not the computer. 6. If it all does not work, it may be an issue with the cable connecting the computer and printer. You can try to use different cable if you have any. 7.Also, Go to the Control panel by clicking on Start. Click Add or remove(Programs or Programs and Features in Window Vista and Window 7) and uninstall the printer. 8. Now, insert the disk that came with the printer (if you have not any, you can download from the manufactures's website) and install it back.
Posted on Apr 25, 2010
I need a computer Aires k3 user manual to download
Function Keys
Fn + Esc:4 levels backlit brightness adjustable,suitable for use days & nights
High light - Medium light - Respiration light - Extinguish (High brightness by default when starting up).
7 Multimedia Shortcut Keys: Stop, Fast forward, Rewind, Play/Pause, Volume-, Volume+, Mute
3 levels keyboard speed adjustable:
Fn+F1 : 21 byte per sec(80/S)
Fn+F2 : 30 byte per sec(60/S)
Fn+F3 : 63 byte per sec(40/S)
Fn Multimedia Combination Keys:
Fn + F4 Mute
Fn + F11 Lock/Unlock all keys
Fn + F12 Lock/Unlock Windows Key
FN + W : Switch WASD keys and Arrow keys.
Fn + Tab:3 colors adjustable backlit
Jan 28, 2017 | Audio Players & Recorders
HP PSC 1315 All-In-One. Just changed ink cartridge, but prints dim and blurry.
Try taking the cartridges out clean them Unplug the power cord from the back of the printer while the printer is off and let it be unplugged for 60 secs Plug the power cord back in and wait for the 30 secs and then insert the ink cartridges it would try to print the alignment sheet... plz complete the alignment and it should work properly after that
Oct 21, 2010 | HP PSC 1315 All-In-One InkJet Printer
Keep copier ready; disable powersave option
This is going to be a user program:
1) press and hold both light and dark keys
a) the 2 buttons to lighten and darken copies
b) hold both for 5 sec until indicators light up
2) use the left copy quantity key show 2
3) press your copy key
4) use the right quantity key to change to 2 (max 90 sec)
5) press the copy key
repeat step 2 but change to 3 with left quantity key
press the copy key
change right number to (4 = 60 min, 1 is default at 5 min) then press your copy key.
Once done press both light and dark key again to exit
Note*** changing shut off timer and preheat will effect copy lamp ready state. Every 60 sec or so the scanner will move and reset. Some people do not like the noise is makes all the time. If you don't you can always change it back to the defaults. 2=0 and 3=1.
Oct 12, 2009 | Sharp AL 1631 Copier
Forgot router login for netgear router wgt624
Reset the router from back , Hold the reset key for 30 sec , Make sure router is powered on , Turn off the router for 30 secs and then turn it back on , Your router login would be username : admin and password : admin factory default
Regards:
Chandan
Sep 07, 2009 | NetGear WGT624 Wireless Router
Printer will not finish shutting down and won't turn back on
Try to unplug the printer wait for about 60 sec, and plug it back in.
Sep 03, 2009 | HP Office Equipment & Supplies
RICOH FT 7650 shuts itself off when not in use after 45 minutes
Enter in the user mode:
1.Press the Clear mode key.
2. Press the Clear/Stop key more 4 sec untill the user tool menu appears on the touch panel.
3.This copiers has more 12 user tools.You can see 5 user tools on the display at the same time.Use these keys to see the rest .
4.AUTO RESET: the copier return to the initial condition autommatically after your job is finished.(after 60 sec)
5.SCREEN SAVER :when the copier does not detect anyone operating it for selected time the display turns OFF.(60 sec).
6AUTO OFF:Whwn the machine is used after weekly timer has turned it OFF the copier will turn itself back OFF after the selected time.The auto OFF time can be set from 1 to 999 minute or the function can be turned.(I recomanded setting level OFF).
Aug 31, 2009 | Ricoh Aficio 450 Copier
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Ringer
If you are using Call Frwd No Answer use code # 603 or if you are using Call Frwd Busy/NAns use # 604 in the following set up.
Press " Intercom/ PDN " plus above code ( #603 OR #604 )
Enter Destination ( Usually Voicemail Access Code )
Press " Speed Dial "
Enter time delay ( 08 - 60 sec )
Press " Redial "
Time delay is default at 12 sec ( 4 ring cycles )
Mar 11, 2008 | Toshiba DKT-2010 Corded Phone
My printer says INcorrect Cartridges
okiz...try to do a partial reset on that on---press and hold the # 3,,while the printer is on....if problem persist do a power cycle....unplug the power cable of the printer for about 20 sec. and turn it back again....semi full reset restores the default settings and refreshes the registry press and hold the # 6 while plugging back the power chord to make it on...okiz...have a nice day
Dec 27, 2007 | HP OfficeJet 7310 All-In-One InkJet...
12 people viewed this question
k24674
