Question about Water Heaters
My hot water has gone off. It was working this morning and the pilot light has not gone out. How can I check for other explainations?
  • 1 more comment
  • espdinner Apr 25, 2010
    Thanks for responding so quickly!
    I have turned the thermostat up to check the effect on the radiators and they are working fine. Would this be the case if the thermocouple was the problem or not?
    Is a Potterton Osprey CF 150
  • espdinner Apr 26, 2010
    Many thanks Clay,
    I found the root of the problem, the kids had turned the immersion heater on and for some reason it had knocked the hot water off. All appears fine now.
    Thanks for your helpful time and advice.
  • 2,841 Answers
The pilot light is working so you know you have gas but you also know that the gas is not coming on. The pilot flame should be bright blue with the tip of the flame having a ting of yellow. A yellow flame is caused by a dirty pilot tube tip. Split flame is caused by dirt in the pilot tube. If the flame is not hot enough it will not tell the thermocoupler to turn the gas on. If the thermostat has not been moved and is still at the correct setting then I would suspect the thermocouple is bad. The thermocouple is mounted right next to the pilot light. It senses if the flame is hot enough for the gas to come on. If the pilot flame is not touching the coupler then it will not allow the gas to be turned on to the burner. Check the thermocoupler and see if the flame is touching the probe on the end. If not adjust it until the pilot flame is touching the coupler. If the flame is properly adjusted then replace the thermocoupler but shut off the gas supply before doing so. It will look like this. My hot water has gone off. It was working this - 0ec43e2.png
Posted on Apr 25, 2010
Testimonial: " Thanks! I have turned the thermostat up to check the radiators and they are working fine. Would this be the case if it was the thermocouple?"
  • NOT ME Apr 25, 2010
    Sorry I assumed you was talking about a stand alone hot water tank and not a hot water home heating system. If you have hot water to the radiators then the problem is not the thermocouple if the same hot water system is supplying heat and hot water. I am confused as to exactly what type system you have.
  • NOT ME Apr 26, 2010
    So very glad you found the problem.
Water heater pilot light is out, cant restart intelli vent controller
Possibly the air intake located at bottom of heater needs to be cleaned with feather duster under water heater.
Read your product manual for steps.
Copy following link for general illustration.
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
http://waterheatertimer.org/pdf/Flame-Arrestor-Screen-Cleaning.pdf
Other causes can be bad intellivent gas control valve, poor venting, hot attic, low gas pressure, dirty combustion parts, tripped FV system.
Copy following link for available intellivent troubleshoot resources:
The service manuals are large files and open slowly.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Jul 26, 2012 | Water Heaters
I have a Biasi Riva Advance HE Combi Boiler. The pilot light and fan dont seem to be working, I can hear a click when I run the hot water tap and a click after I turn tap off,
Have you bleed the air from system and run hot water and heating at the same time , bleed the pump . you could have air in the pilot after turning it off
May 01, 2017 | Water Heaters
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Aug 09, 2011 | Reliance Natural Gas Water Heater Control
Hot water is not working in all faucet, no hot water
First do the simplest thing and check to make sure the pilot light is working on your water heater. There should be instructions posted on your unit of how to check and also how to light it if it has gone out.
Dec 13, 2009 | Water Heaters
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
Pilot Light will not remain lit
Try this, turn the black gas ****, on top of the control box, to the Pilot position. Set the temp. control on the front of the box to the desired temp. Then, hold a match or whatever else you use to light it, next to the end of the pilot, then, while holding the match to the pilot, press the reset button on top. When the pilot lights, continue to hold the reset button down for about 1 minute. Then, after a minute, turn the gas **** to the ON position, then it should remain on.
Jan 20, 2009 | Water Heaters
Gas hot water tank, pilot light
Look inside the water heater when it is heating the water, the flame should be blue. If it has yellow tips on the flame, it needs an adjustment to the air shutter. There is a nut on this air shutter to make this adjustment. This adjusts the air gas mixture. You may first try just simply tapping on the burner lightly to loosen any debris that may have built up and vacuum it out. MAKE SURE YOU TURN OFF THE GAS BEFORE CLEANING THE BURNER!! Also, check for drafts that may be blowing out your pilot light, Furnace register or outside drafts on windy nights. Some water heaters have an automatic shut down if the water heater gets too hot, so don't have it set to its hottest setting. Most water heaters only last about 10 years or so, It could be you are ready for a new one....Joe
Dec 16, 2008 | Water Heaters
Water Heaters Logo
507 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
