Question about GE Spacemaker JVM1640SJ Microwave Oven
Replaced the range top bulbs but still cant get the lights to work onmy GE JMV1603WB004
  • GE Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Apr 28, 2010
How do I change light bulb under a 2009 ge microwave/model no.lvm1750dm1ww
The range top bulbs can be replaced by removing the screw that holds the glass and frame to the underside of the unit, they swing down, the bulbs usually screw in, the power needs to be turned off by way of unplugging the unit before replacing the bulbs, the interior cavity bulb can be replaced by removing the top grille and accessing the socket assy from the front. Pleazer Appliance...
Dec 22, 2014 | GE Microwave Ovens
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 19, 2014 | Microwave Ovens
I have a GE JVM 1870 over the range microwave with the active vent. The interior light is out which is a simply fix. How to I get to it?
follow this steps and fix it. God bless you
  1. Light bulb If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control board If your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Dec 09, 2013 | Microwave Ovens
The surface light is out. Need to replace with
You can find and order them easily by entering your full model number from the tag in or on the unit and also find helpful exploded view diagrams here.
Also, your owner's manual should cover that, and they usually have the GE part number inside. You can download them here.
Note that these are likely halogen bulbs, so do not handle them with bare skin. The oils on the skin will reduce their service life.
If after replacing the bulbs, they still won't work, won't shut off, or you have trouble with the fan or turntable, the filaments may have shorted, causing a surge which damaged your control circuit board.
May 13, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Replace the grille and screws.
Jun 26, 2009 | GE Microwave Ovens
The interior light on my microwave convection oven doesn't light.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Nov 20, 2008 | GE JVM1490 Convection/Microwave Oven
Replacing interior light bulb for ge spacemaker xl1800
If it's an over the range type, remove the vent grille across the top to check if you can access the bulb fromthere. There may be a panel on the bottom covering the light(s), instead.
you may have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy,
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
hope this helps dont forget to rate this
Sep 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replace light in overrange GE microwave
Advantum 120 over range microwave - with burned out interior bulb: Remove top fron grill cover -- held byu 2-3 screws on top. Remove sheetmetal plate that lies parallel to top of unit, just to the right of the square plastic porting on the far left of the unit. The sheet metal plating is about 12" wide and 8" deep and is shaped like 2 overlapping rectangles. It is held in place by 1-2 screws. (I don't recall if you needed to remove other plastic grid on right front -- I did, but I was still searching for the bulb). The bulb is located about 5" from the left side and about 2" in from the front, covered by a small sheetmetal box. THe bulb looks like the little halogen bulbs used in low-voltage outdoor lights - but is slightly larger - DO NOT REPLACE WITH THAT KIND OF BULB). Remove the one screw holding the box, unplug the bulb and find a replacement. Can't tell you where to get a bulb -- that's what I'm doing next. Good luck.
Jul 25, 2008 | Microwave Ovens
Replacement bulbs still do not work
Most electronic control boards have undersized circuit wires that can't handle a catastrophic lamp failure. The circuit trace will open like a fuse. If you or someone knows how to use a soldering iron, this can be repaired.
1. Remove the top grille. (Two screws on top)
2. Remove screw above button panel. Push up on panel to remove.
3. Remove circuit board from panel. Look on reverse side for open circuit trace.
4. Repair circuit trace...lights work again....
If you need further assistance, let me know
Regards,
reg501
Jul 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
46 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
