Question about Whirlpool Duet GHW9150P Front Load Washer
The dryer is going completly off.and will not come on.
the dryer control panel will go completly blank and will not reset unless I oppen the circit breakers and leave them open for several minuits. Sometimes the panel will control lock will set and will not unlock unless I reset the circit breakers. This is becomming more frequant. Help!
    President:
  • 1,554 Answers
The machine control electronics board which serves as the "brain' of the machine is starting to fail. It is most probably overheating causing it to shut off as it turns on only after it is left unplugged and open for several minutes which allow it to cool down. Specify the exact model number of the machine for the specific replacement part and for more specific advice.
Posted on Apr 25, 2010
Samsung Range control panel won't turn on.
Check the voltage at the ac cord. Make sure you have 240 there. Sounds like your missing one leg there
Mar 24, 2014 | Samsung NE595R0ABBB 5.9 cu. ft. Large...
Led lights on control panel are flashing and dryer will not start, check filter light is on
leave this machine unplugged for several hours. Make sure all the lint is free and clear. This machine needs to be plugged for several several hours to reset itself unless your model has a reset option available.
Jun 05, 2012 | LG DLG2524 Gas Dryer
My Kenmore elite HE4 quiet pak 9 electric dryer is working, but it emits a constant series of 3 beeps, and sometimes shuts off before the cycle is complete. I have to unplug it to stop the beeping....
You are getting moisture in the control panel buttons. After a while the panel will not function at all. The light in the dryer tub will still come on when the door is open. When you unplug your machine and it sets for awhile you are allowing the moisture to dry and the machine can reset. Some people use a hair dryer to dry out the control panel for a temporary fix. Eventually, you will have to get it replaced once it stops resetting for you.
Oct 25, 2010 | Kenmore Elite HE4 Electric Dryer
Last night I dried multiple loads of laundry . . . the dryer worked fine. This morning when I pressed the button to turn it on nothing happened. The control panel is completely blank, as if the dryer is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 24, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer was working fine...then
You have a short circuit in the dryer. Check the incoming wires at the cord terminal on the rear of the dryer. If these wires are OK it could be a shorted heating element.
Sep 08, 2009 | Whirlpool LER5636P Electric Dryer
My Kenmore Elite, Model 11062042100, has been working fine but now the control panel is totally dead. The interior light is working, so I know it is getting power. Any ideas? Thanks!Shaun
OK, if you are certain that the unit is receiving a power current, this will most defiantly confirm a major chip fault in in the main control board.
Try to wake the control by cutting the power to the unit for 5 minutes. if the damage isn't severe, this will either, reset the program or, render and error code. if both do not appear and the control remains blank or dead, after the reset, replace the main control board.
Jun 19, 2009 | Kenmore Elite HE4 Electric Dryer
Maytag MDB7130AWB dishwasher blows circit breaker.
These have been known to leak water into the door panel. If so the water can cause a short. Your breaker is keeping the machine from lighting up. Check any seals that may have been braeched in the door. Start at the dispencer latch
rubber.
Mar 07, 2009 | Maytag MDB7100AWB Dishwasher
CONTROL PANEL ON DRYER
Have you tried plugging and unpluggin the machine?
Mar 15, 2008 | Dryers
Dryer screen shows 8.8. when I go to dry a load of clothes and won't work
We had the same problem - you might try and hit the panel with a blow dryer to heat it up if it's in a cold garage - it may buy you some more time - It took mine 2 yrs to go out completely - when it finally did - I took out the curcuit board and found dark discoloration around the cluster of four resistors - after reading dozens of posts from multiple sites, decided to replace those four resistors and the three main capacitors in the same area just to cover all bases. And for only a few bucks - it works like new again!!! A service call could cost you @$300 - $500 from what other are saying! eek if that's really the case!
Jan 19, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
