I have a DTA800 digital box, when I turn it on it also turns on my RCA home theater system, how do I stop this?
  • 22 Answers
They are both rca and are most likely using the same on commands
Posted on Apr 25, 2010
How do i connect my home theater system so that i may use the speakers to here my cabel channels
How to connect your cable to your home theater system depends on several factors. So what I'll do is try to cover all of them.
If your home theater RECEIVER has various types of inputs then there will be several ways to do it.
If your cable box has various types of outputs there will also be several ways to do this.
Let's start with the basics.
All cable boxes that I have seen have Red colored and White colored (RCA type) stereo outputs. This also applies to any stereo or Home theater system which will have multiple inputs of the same type and color. If you connect a cable between the cable box's Stereo Outputs and into the cable (or satellite audio inputs of the Home Theater system. Then Switch the Home theater input to the same input, that will work.
If the cable box has an coaxial digital output ORANGE "RCA" TYPE PLUG) and the receiver has the same, connect a single RCA connector between the two. Then go into the input menu of the receiver and change that to digital as opposed to analog. (The red and white ones)
If the two pieces, Receiver and Cable box have optical connectors (little black square door with a red light behind it). Use that and set up the Receiver to receive a digital audio input.
With either the coaxial or optical connections used. You will have full surround sound when it is being broadcast.
Another possibility is that the receiver has discrete RCA input connectors for Left and Right Front, Center, Left and Right Rear and Sub Woofer. Again, if the cable box has these, have at it.
The last one is really simple.
If your equipment is relatively new there will be an HDMI connector on the back of the Receiver. If there is one on the cable box, which often there is for HD cable. Get a single HDMI cable and connect the two together.
I think that is all I know about the subject.
It might be a good idea to print this little article I wrote for you and use it as a reference while looking at the back sides of your home theater receiver and cable box.
I hope I've been a help to you. Please let me know.
Best Regards,
Mark
Jan 21, 2011 | Panasonic Home Theater System System
I have an RCA Home Theater System RTD315WR, the blue standbye light is on, when i push any button the blue light turns off. Nothing is working on it. Ive tried unplugging it and plugging it back it....
I purchased the RCA Home Theater System RTD315WR less than a year ago. Just a little over a month ago, the door would not open leaving my DVD still stuck inside. Upon many attempts trying to retrieve my DVD NOTHING HAPPENS. As a matter of fact, the standbye light comes on, and when I push the button the light tunrs off completely and NOTHING happens. Since I no longer have my receipt or box, Wal-Mart would not exchange it. I am in the process of writing a letter to Wal-Mart Headquarters in hopes they will assist me in this matter.
Oct 29, 2010 | RCA RTD315 Theater System
I hooked it up the way the manual said and it doesnt work
Try whatever applies best below, in order...
Cable Box optical Digital Audio to Digital Audio In. (This brings TV-related multi-channel and normal audio into the receiver so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the system on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box HDMI, Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
May 01, 2010 | RCA RT2380 Home Theatre System System
How do connect a digital cable box to Home Theater system so you can get the audio from cable through the Home Theater?
Audio out from the cable bos to audio in to the home theater using rca cables. You may choose video, aux input etc on the home theater. Just select the one that the cable box is connected to.
Nov 23, 2009 | Radio Communications
What is the codes for a sanyo tv that will connect to a rca/dta800 converter box. I have lost my manual and need to the codes for a Sanyo television.
not for sure but try 007, i have a different brand converter box hooked to a sanyo tv and it's code is 007, i will try and find out more if i do i will post it
Nov 19, 2009 | Insignia Digital-to-Analog Converter for...
Scanning channels stops at 20%
the exact same thing happened to my dta800. i unplugged the ant. input at 20 percent and then plugged it back in when it resumed. i dont know why this worked, but i now get my 25 channels instead of the 4. this digital garbage is annoying all around. hope this helps. senor punko
Jun 19, 2009 | Televison & Video
When I hooked the DTA800 to my RV atenna
My understanding is that the Digital signal is weaker than the analog, so need a stronger antenna to pick up the digital signal, and MAY still not get any reception at all. Have you considered satellite for you RV? Won't need the converter at all then.
Feb 22, 2009 | Insignia Digital-to-Analog Converter for...
Need sanyo tv code to connect rca/dta800 converter box
sanyo 037,082.083.124.198,268.274 Press program, three number combo, ok, check volume control for function
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Need a progam code for rca dta800
I just tried their web site and it worked! They have the codes. www.1800customersupport.com/rca
or here is the direct link: http://www.1800customersupport.com/productdocuments/DTA800B1_Program_Codes.pdf
Hope this helps others who have had the same problem. Mine did not even come with these codes!!!
Jul 07, 2008 | Hitachi 57F510 57" Rear Projection...
27 people viewed this question
 Grubhead
Grubhead
