Question about Microwave Ovens
My hand sprayer on my sink is leaking every time I turn the water on. It's leaking from the sprayer and in dripping under the sink. How can I fix this?
    Guru:
  • 415 Answers
Check for a leaking O-ring/Washer/Seal and replace. Sometimes the internal parts of the sprayer head will wear out. Replacement sprayer heads can be obtained from your local hardware store.
I'll look forward to hearing back from you. :-)
Posted on Apr 26, 2010
I have a Price Pfister faucet model F-534-70CC. It won't swivel,what do I do????
If this was a new install, back off the retaining nut a half turn. Most people have a habit of overtightening.
If it has been installed for quite some time, check to make sure that the sprayer hose is not wrapped around something or wegged somehow (under the sink).
Jul 08, 2011 | Microwave Ovens
I'm trying to change the kitchen faucet and the shut off valves under the sink will not turn, I've tried to spray them with WD40 but they still won't turn. I live in a Condo so I cannot shut...
If you can't work the shutoffs on the water lines under the sink, your only choice is to contact your condo maintenance people. They need to have some way to shut the water off to your unit when they make repairs. They can tell you if there are some more valves in another area that you can access, or they may have a maintenance closet somewhere and can turn the water off for you so you can make the repair.
Sometimes you can turn a sticky valve by using a large set of channel-lock pliers or similar type on the knob so you can get leverage. They look like this if you're not familiar with the type:
If it's been a while since the valves have been used, they often don't want to move without help. Once free, they may work fine, but sometimes it's a good idea to replace the shutoff valves as part of the new faucet installation. They're not expensive and you'll know they will work if you need to shut them off in the future. Get "ball-valve stops" which make a positive shutoff. Stops that use a rubber washer can sometimes let water trickle through (or more than trickle!) when shut off. Depending on the kind of valves currently installed and the type of pipes supplying your water, you might want the condo maintenance people to do the replacement. But if 1/2-inch copper pipe is what you have and there's a couple of inches between where the pipe comes through the cabinet back or bottom and the current valves, you can just cut them off with a tubing cutter. Then you can replace them with valves that just slide over the pipe and are fastened by tightening down a compression fitting (tightening a nut, in other words).
You should also plan to use new supply lines from the shutoffs to the faucet. Again, they're cheap and the old ones can sometimes leak when you try reconnecting them. Corrosion and mineral build-up from hard water can lead to poor sealing. The current ones may also be clogged with minerals, and new ones will give your new faucet full flow.
Once you've got that problem of turning off the water supply solved, it's usually not too difficult to change the faucet. Make sure you have a basin wrench on hand; on many faucets it's impossible to reach the supply connections with any other kind. The box from the new faucet may tell you if can get away without one.
Good luck with the project, and thanks for using Fixya!
May 28, 2011 | Microwave Ovens
Keurig Coffeemaker says to descale. How do I do that?
Hi, unplug the coffee machine and remove the cup.
Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
Unplug the machine and dump the water into the sink.
Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Apr 28, 2011 | Microwave Ovens
Never have used a garbage disposal, now after 4 month and using it only about 30 times the water in the sink will not drain. When I turn on the garbage disposal the water in the sink swirls so I know it is...
hello fowl..... you have a blockage in the garbage disposal. you can use a chemical drain cleaner and pour it into the sink where the disposal is located. you should also look into that drain with a flashlight to make sure that there is not a fork or some other object causing the blockage. If you do not choose to use the chemical, you can also disconnect the disposal using the wrench that should be under the sink where the disposal is located. if you choose this method, have a pail handy to catch the water. also unplug the disposal before you work on it. Joe
Apr 24, 2011 | Microwave Ovens
We have a steadily dripping tap. Can you please help? thank you.
You don't say anything about what kind of faucet you have, so this may not apply. But if yours is the kind with handles you turn to control the water, you probably have worn-out compression washers. In this kind of faucet, water is shut off by pressing a rubber washer on the end of a threaded stem against an opening in the faucet body. When you turn the handle, you move the washer away from its seat and the water can flow. Over time the washer gets worn and no longer seals off the water. Also, the valve seat the washer presses against can wear and allow water to sneak past the seal. The result is that annoying drip or a steady trickle.
This site, among many others, shows how to change a washer and fix most drippy faucets. If you search for "repair a leaky faucet" you'll find lots of sites to pick from, including many with videos. If you faucet is not a compression type, a single-lever cartridge for instance, there are links to other repair procedures.
If your faucet is old and the parts very badly corroded and worn, you might want to fix the leak by replacing the entire stem as a unit. You can find replacement stems for most brands of faucet at big-box home improvement stores and at many hardware store. It's a little more expensive, but often much easier to unscrew the old one and pop in the new than to start trying to get the old washer off the stem.
A last tip: Whenever you do any work on a faucet, remove the aerator from the spout and run the water to help clear the line. If you just turn the water back on and run the faucet, debris that was kicked up during the repair can clog the aerator screen. Then you're left wondering why you get only a weak trickle or no water at all after you fixed the trouble.
Mar 10, 2011 | Microwave Ovens
My refrigerator has a leak behind the drawers on the inside . I have since had to put a towel at the bottom of the drawers or it will start leaking down the front and onto the floor every couple of days....
Moisture condenses out of the cold air inside the fridge. Many refrigerators have a drain tube in the bottom to allow the condensate to run into a drip tray under the refrigerator (behind the trim panel on the bottom) where it evaporates. Over time this tube can get clogged by food particles and the water backs up, eventually running over the bottom edge onto the floor. You can use a straightened out coat hanger or other stiff wire to clear it out. This should get the water back into the tray where it belongs.
Jan 21, 2011 | Microwave Ovens
I have a Moen 98043 kitchen sink faucet that is leaking water from the top, any ideas how to fix
Hi Adonish,
If you give Moen a call at 1-800-BUY-MOEN someone will be able to assist you and figure out what the problem is.
-Olivia
Jan 03, 2011 | Microwave Ovens
I am unable to use the Bellagio water cooler now as the cold water dispenser is leaking. There is a constant drip so I had to remove the water bottle, then drain all the water from the reservoir. I have...
Go to www.super-electric.com and send them a message about your problem. They have parts. I can't tell you if they will help you or not, I have just emailed them today as well. I have both sides of my 1 year old water cooler leaking, model W074DRF11BQD. (from Zellers) I have hardwood floors and I would rather throw this unit away than risk water damage. If anyone is reading this and thinking of purchasing one of these Bellagio water coolers, spend your money elsewhere - THEY LEAK!. My husband is very handy and has just spent 2 hours on it with NO success. The parts are defective - this unit is NOT full of complex working parts. One plastic part causes pressure on the valve and causes a leak(s). After light usage and nothing damaging it, 8 months old one side went and the other side has been leaking for a couple of days and we are just coming up to a year. If anyone else had this problem and fixed it, I would love to hear the solution.
Dec 26, 2010 | Microwave Ovens
I installed a new sink and everytime I turn the water on the water lines shake
The reason why the water lines are shaking is because the new sink is letting more volume through than the old one. When you have more volume and then stops when you turn the water off it is going to cause a **** in the line. A way that you can fix this problem is turn the inlet valve down. So it slows the water volume down. Another thing that can cause the lines to shake is the copper water line was not reamed.
Oct 19, 2010 | Microwave Ovens
Microwave Ovens Logo
131 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
