Question about Amana Radarange Microwave Oven
Looking for instruction manual for a model RRL-8TD radarrange
Have lost instructions for russell hobbs oven/microwave model no RHM20105-H serial no 0133100063
I think this the manual your looking for. That 5 is the model appears to be a S instead. Roll your mouse over the large black rectangle for pop-up download menu.
Russell Hobbs Microwave Oven User Manual ManualsOnline com
Dec 24, 2014 | Russell Hobbs Microwave Ovens
Instruction manual for Russell Hobbs Cafe Continental Model 3344
I am look for the Instruction manual for Russell Hobbs Cafe Continental Model 3344
Dec 10, 2012 | Microwave Ovens
I'm trying to find a replacement glass tray for my Amana microwave oven. The model number is RRL-10TD. The date on the back of the oven is 1982.
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Jan 11, 2011 | Amana Microwave Ovens
I have no manual only model number
If you require an Owner's Manual, you can find one at managemyhome.com. Just type in the model number that you have this question listed under, in the "Manuals" link. and the owner's manual is available in a .pdf (adobe) format that you can download or print for FREE.
Included are the operating instructions, installation instructions, use and care instructions and specifications.
I hope this is what you were looking for.
Oct 21, 2009 | Sharp R-1874 Convection/Microwave Oven
Moved oven. Keypad can not set time. Amana RRL 9TC
After so many years, the electrolytic filter capacitors dry out and these become more susceptible to disruptions and glitches.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, I would say your control unit (called the "net module") needs to be repaired or replaced.
If this item is available anywhere, it may take several weeks to get and will likely run well over $150.00.
If you decide to look for parts, the proper model number format is RRL-9TC and it also has one of four manufacturer numbers on its tag: P7553302M, P7553303M, P7553304M, or P7553306M.
Be sure to have both numbers handy.
The original part numbers for the net module seem to have been R0163049 and then R163079A.
Good luck.
Feb 02, 2009 | Amana AMV5164 Microwave Oven
I have an Amana microwave Model RRL-10C. The magnetron modulation SCR has delaminated from the foot mount and shorted in the closed position due to thermal failure(thank goodness the nuke still works but...
I wouldn't suggest trying to modify the triac control circuit.
Without a schematic I couldn't begin to advise you on how to do that or to value or the parts that might be bad.
And I truly doubt that the schematic can be found.
I would kind of expect the opto to be bad, and maybe a resistor or two.
They would need to be replaced with the right values and an acceptable opto.
You may get lucky and find that the opto and resistors are all okay.
You can find the triac here. Looks like the GLC16-50 or GLC16-50S would work for you.
That's about all the help anyone can provide you, honestly.
Good luck and be careful!
Jan 18, 2009 | Microwave Ovens
Light went out in Amana Radarange Microwave.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Nov 21, 2008 | Microwave Ovens
Amana Radarange Microwave Oven Logo
70 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
