Magnavox 50'' Plasma tv won't turn on.
Magnavox 50'' plasma tv. model 50MF23ID/37 won't turn on.
I turn the tv on a greenlight comes on, after a few seconds a click and then a blinking red light. Unplug the power cord red light blinks several times then a green light, then it goes off, I plug the cord back in and a green light comes on and then goes off, I push the on button and start the process over 3 to ten times before the tv will come on and then wait for picture to come on after about 20 to 30 seconds. what could or would be wrong? Thank you
  • 17 Answers
SOURCE: Red blinking light on a Magnavox Plasma TV
Goater, is the fuses suppose to be white? Is that normal or blown?
Posted on May 05, 2008
  • 3 Answers
SOURCE: 50mf231d/37 magnavox plasma
i have the same problem but i play with it by pluging it in multiple times and i hear it click on then off eventually the time between it clicks on then off is longer until i finally get it to stay on .I have to do that everytime i use it . Also the update wont work for me either tried everything. It must be with the power supply becuse once i get it on it stays on, and if i turn it off after its been working for a while it comes right back on perfectly. Only when i leave it off for a few minutes the symptoms start right over.This is what i do for about 5 minutes of plugging it in and out it flicks on and then off about 2 seconds later after that ii finally get it to flck on then off about 6 seconds later. 5 more minutes of pluging it in and out it takes about 10 seconds to flick off this is when i know it is about to work.finnally the green light will stay on and the tv wont flick off you can turn it on and of with the button wait 2 min to see if the picturecomes on repeat last step until it works.This means everything works great exept for the power supply for enitial startup. I beleive its a capacitor . I will check and report back.
Posted on Nov 24, 2008
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Posted on Apr 28, 2009
dsacco86
  • 1077 Answers
SOURCE: Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Posted on Aug 12, 2009
  • 8457 Answers
SOURCE: red light keeps flashing,no picture
Ur power ic inverter board is dead.
U need a new one.
Posted on Aug 20, 2009
My magnavox model 50MF23ID/37 is 4yr old. tv wont
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.
http://www.discount-merchant.com/
Here you can get your lamp that most likely needs replacing.
Mar 26, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox plasma tv model 42mf230a/37 sound but ni
Replace lower scan converter PCB, which plugged into Y-Sustainer Board, located to the left of the display if you poke back cover open. There are 2 of them, but in some models might be the one, long PCB.don't wait to fix it! otherwise, you will knock out Y-
Sustainer and upper scan converter. That will cause you to spend few hundreds to fix it.
Good luck,
Alex's TV Service,
Philadelphia,
Pa, 215-806-5980.
Jan 21, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I have a 50' Plasma HDTV and when I turn it on
First thing to try is replace any swollen capacitors on the power board.
Nov 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
First thing to try is replace any swollen capacitiors on the power board.
Nov 01, 2009 | Televison & Video
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
How many Main Boards are in the Philips 50'' Plasma TV model 50pfp5332D/37?
has only one main board
has many sub bords supporting tat main board
Mar 08, 2009 | Philips 50PFP5332D 50 in. Plasma...
Issue:
Cause:
Service:
Solution:
1. Unplug your TV
Jeff G
Portland, OR
Feb 10, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
Electro Med Services...
