Question about Sony Playstation 3 (PS3) Console
I went on bbciplayer and i left it on all night and the next day i come to use it and i put it on it was ok 4 about 3 secs then it went a yellow colour made 3 beeps and went off.Av tried turning off the thing from the back and turning it on with the arrow on as well it just makes a really big noise and goes off again plzzzzzzzzzzzzzzzzzzzz helpppppppppppppppppppppppppppppppppppppppppp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 691 Answers
It might be the hard drive so you could try replacing that with another 2.5" sata drive if you ave one. or it sounds like it might have overheated. Contact Sony or a specialist repairer. This is not one you can fix
Posted on Apr 25, 2010
  • Daniel Bakewell Apr 29, 2010
    ...further research suggests you might get this fixed, check out;
Power led light on when pressing power it tuns on and goes of right away? power still lit..
I have the same problem, did you figure out what the problem is and solution by any chance? i purchased it recently, it started doing this the night after i left it on for the night. next day everytime i turn on, it turns off in 2 sec. after a month i tried a shot, it started and stayed up for 1 min may be... then same thing again 2 sec. i guess i have to wait for a year to turn it on .
garden led light
May 29, 2012 | Office Equipment & Supplies
I had a constant grinding coming from front passenger tire. Replaced Caliper and put the worn pads back on for a day, the constant grinding went away. It would still grind while braking,hitting a bump
It sounds like the brake pads are metal to metal, when you turn the flexing of the wheel makes them touch the rotor and grind. This can rarely be caused by a badly worn wheel bearing as well, have both brakes and wheel bearing inspected.
Mar 02, 2017 | 1999 Pontiac Grand Am GT
I have 85 toyota have changed water pump reader cap thermostat and still gets hot boils out water but when you put cold water it's ok for the rest of day sets over night start next day gets hot ag
did you let excess air out of radiator? after filling let it run for a few minutes with out radiator cap and make sure the water does not go down and serculates after thermostat opens, refill if needed
do you notice moister under vehicle in the morning ? possibly a gasket could be leaking.
Mar 30, 2012 | Cars & Trucks
I have an ASUS model X83V and my screen has been flickering (not in brightness, but actually going fuzzy and "jumping"). The flicker can take upwards of 1 hour or more before it goes away, but usually...
my son has this same machine and after a year of almost daily use it developed this same flicker you describe, about every 4 secs, then it got much worse, almost like an old tv rolling. i took it all apart and inspected it all. didn't see anything really troubling.
yesterday it worked fine all day while i installed a bunch of updates for another problem. i left it on all night doing some other things. this morn when i got up it was still ok. then after a while it started in again, every 4 secs.
so i've been troubleshooting the damn thing all evening and have come to the conclusion its from over heating, probably cause of the crappy heat sink connection. i noticed if i take it outside in 40 degree weather and leave it a couple mins on the hood of my truck, it goes away. bring it back in and after 5 mins it comes back. take it back out and its fine again in a few mins. also, yesterday my house as much cooler. my fire was out and it was in the upper 60's in here, today as soon as it got to 76 in here, and it was above that all day, it started acting up
so i think my next step will be to try and make a better union between the chips and the heat sink itself. you should try a test with yours. start it up, make sure its flickering, put it in a cold space for a few mins. just be caustious of condensation.
Oct 23, 2010 | Computers & Internet
Green light to yellow in 1 sec then blinking red light
Hrm, is it well ventilated? Is it in an enclosed space? Try putting it out in the open so all the vents can properly breath. If that still fails to work you may have to get it serviced. You can contact sony at:
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/help-support/PS3
Hope this helps. Also be sure to rate if it did or not.
Jun 24, 2009 | Sony Playstation 3 (PS3) Console
2001 Pontiac Bonneville won't start
have you not left any load on overnight?..like park light or left the door partially open and the dome light would be left on?
have the battery recharge and the next night, make sure that no light would be left on the car.
if it would drain out again, have it recharged again, use it and on the night, make sure no light is left on the car, then remove the positive pole on the battery overnight.
the next morning, put the positive cable back and start the car.
if the car would start, then no problem with the battery, if the car would not start, then return the battery because it is defective.
tnx 4 using fixya,
drcool
Oct 20, 2008 | 2001 Pontiac Bonneville
Left refrigerator door open over night, next day it stopped working
sounds like you sucked in a lot of warm air over night freezer still working? just the refrig went out???easiest solution empty unit completly, unplug and leave doors open let al frost melt out 24 hrs later plug back in and you should be find
Feb 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Dell Dimension 5100
buy new power suplly for it ok
Feb 11, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
