Question about Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio
Nedd to reset radios back to factory settings.
Need to reset radios back to factory settings. Having trouble communicating with other radio. Not able to get Radio weather station
  • Leon Bayless Apr 25, 2010
    could not find instructions in manual to reset to factory. Having trouble with both radios, it may be due to operator problem changing setting s trying to solve problem. Battery strength shows good. Thanks for your efforts.
    Not understanding solution. Where can I send radios to have them checked?
    Problem Solver:
  • 8 Answers
I have a pair of LI7000 GMRS/FRS radios from Cobra, when set on the same channel without CTSS or DCS turned on, neither hears the other, and a third radio (known to work) does not pick them up in any meaningful way either. What could be the problem?
Posted on Jul 17, 2016
  • 713 Answers
Hi,I think the problem is with your tone coded squelch (CTCSS). Your radio channel is like a telephone party line. If your CTCSS is not on, everytime you turn your radio on you will hear anyone on that channel that is close enough to hear.
If you are trying to use these radios for serious communications, that will drive you nuts to hear everybody else talking but not about what you need to hear. To try to mitigate this problem, CTCSS was created. There are 38 different codes. If you for example set your unit to operate on code 11 and your other unit is set to operate on code 12, you could not hear each other.
Now let's add a third unit set to not use CTCSS at all. Neither one of you will be able to hear this third unit but he can hear both of you. Now you set the second unit to code 11 like the first unit. Now you will be able to hear each other. The third unit will still be able to hear both of you but since he is not transmitting code 11, you still can't hear him.
If you are hearing some traffic, it is because they have their CTCSS set to the same code that you are set to. Look in you operators manual for CTCSS Privacy Codes. Set your radios accordingly and your problem is solved.
if you still insist on resetting your device,you can get e full description on how to do this in your users manual,if you don't have one you can get it for free at;www.manualsonline.com
Posted on Apr 25, 2010
    President:
  • 1,561 Answers
What is the signal strength of the radio and is other similar radio able to communicate?
It could be that the signal antenna of your radio is faulty, maybe that is why it is not communicating with other radios. check if others are able to communicate with each other because the fault could be from the radio weather station.
I will advice you check the manual of your radio to get the procedure on how to reset it.
Take care.
  • Sulaimon Jimoh Olayemi Apr 25, 2010
    Have you try to reach radio base station of you radio to know if the problem is from their end because it is possible that they are fixing something, it may b due to operator changing settings in other to solve problems. besides it be weather problem.
    Try to reach them to know what the problem could be.
    Regards.
    I did not say you should send your radio anywhere for check, i only said it could be a problem from the radio base station, maybe they are trying to fix a problem and i said it could also be weather problem.
    Regards.
Motorola t5710: radios are set to the same settings and will not talk to each other...Is there a way to reset them to factory or default?
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units. Trade the battery with a known good radio to see if the problem moves to the other radio, is a simple test.
Jul 09, 2017 | Motorola Radio Communications
Tip
Reset the Radio on your 2001-2005 Honda Civic
If the radio on your 2001-2005 Honda Civic (as well as some other Honda products) has lost power for any reason (i.e. dead battery, blown fuse, etc), you will need to enter the reset code.
The reset code for the factory installed radio is located in the glove box. Open the compartment; On the back of the door, usually near the left side, there should be a small white sticker. The sticker has one alph-numeric set and one set containing five numeric digits. The number set with five digits is the reset code for your factory installed radio.
Turn on the radio. When you see "CODE", use the corresponding station pre-set buttons to enter the code. If entered correctly, the radio should active immediately.
on Jul 29, 2010 | Honda Civic Cars & Trucks
Nedd the code for my radio
You need to contact a dealership to get a reset code.
Dec 29, 2014 | Cars & Trucks
How to remove a non factory radio from the dash of a 1996 ford f 350?
Not having any information on how it was installed, make or model of radio, I can't be of much help. You need to provide more information on what you've done so far.
May 25, 2014 | 1996 Ford F350 Crew Cab
We just purchased the Motorola RDU 4100 radios. 8 of them to mix in with 4 others of the same model number. radios were working fine up until recently when 3 of the radios are now broadcasting the same...
Reset to Factory Defaults (Pg. 34)
Reset to Factory Defaults will set back all radio
features to the original factory default settings.
To do so, press PTT, SB2 and SB1
simultaneously while turning ON the radio until
you hear a high tone chirp.
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Programming instructions begin on page 36.
Best regards.
Aug 15, 2011 | Motorola RDU4100 Two Way Radio
Cant reset my motorola talkabout t5000
Constant static can be a sign of a bad or low battery. If the battery is known to be good, try the radios outside the factory setting to see if the problem persists. If you have no problem when you are away from the machinery, you may need to set your interference eliminator code to a number other than zero. This will turn your eliminator ON, which will block out the radio frequency interference caused by the machines.
If the problem persists outside of the factory, then you should try replacing the batteries. OR possibly just cleaning the battery contacts with a pencil eraser.
The method you are using for resetting the radio will take the radio back to the factory default settings. It will not solve the problems listed above. It will only reset the frequency and code back to the original settings.
Aug 07, 2009 | Motorola TalkAbout T5000 2-Way Radio
My IC-F21 portable radio wont communicate with each other. is there a reset?
You will need the programming software to check all settings of the two radios. If both radios are programmed the same then you need to run tests on why they wont communicate to each other. Unfortunatly there is no "reset" for the radios. Carl
Jul 19, 2009 | ICOM Informatique Icom IC-F21 16ch UHF...
REMOVING DASH
go to dealer Most dealers have a set of keyes that are inserted on the side of radio and removes them NO problem.
Save yourself the trouble. when you take the dash apart it happens most often that tweeks and noises start coming
very arritating
Apr 22, 2009 | Car Audio & Video
How do I Reset my T5000 2 way radio to factory default
The T5000 Talkabout radio default settings are not the same as the CP100 and CLS. The CLS and the CP100 UHF are capable of being programmed to match one another on several frequencies, however, the TalkAbout T5000 is not capable of any of them.
The Talkabout radios, as a general rule, are limited to FRS and GMRS frequencies. The CP100 and CLS are from the business and light consumer divisions. They will do most of the common 56 UHF business frequencies.
If you would like to look at the frequency charts yourself, here are some links.
Here are the frequencies possible on the T5000 http://www.fixya.com/support/p514922-motorola_talkabout_t5000_2_way_radio/manual-362/page-17
Here is a link to the CLS radio manual
http://www.123radios.com/Manuals/clsmanual.pdf
Here is a link to a CP100 user manual
http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Jul 13, 2008 | Motorola TalkAbout T5000 2-Way Radio
Having trouble settimg clock on cd car stereo
how to set clock for a pioneer deh-27mp
Mar 24, 2008 | Car Audio & Video
Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio Logo
1,025 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
