Question about Nikon COOLPIX S710 Digital Camera
My nikon s220 says lens error and makes a clicking sound how do you fix that
I dropped my Nikon s220 and the lens was stuck out and would move in and out repeatedly but never fully in or fully out. The screen said it was a lens error. I did the same as the first poster and manually pushed the lens barrel all the way in until the shutter closed completely. I was a little scared of breaking it fully because it was making lots of clicking noises and I had to put quite a lot of force on it. Then I turned the camera on and off and now it works perfectly again!
Posted on Jul 17, 2011
I had the lense error message due to sand and or dropping the camera. I tried all of fixes above. The final solution? I turned on the camera and before the lense could retreat back in to the body I trapped with my fingers. I then pushed it manually back in to the camera body. It clicked several times while going in. I turned back on, voila! A working camera!
Posted on May 09, 2010
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 25, 2010
4 Suggested Answers
  • 70 Answers
SOURCE: Re Nikon S220 digital camera. Lens error noted -
A tiny bit of grit can jam the gears of the lens. Sometimes a tap can knock it out. Try this at your own risk. Take out the batteries. Don't hit the camera on a hard surface, just use you hand. If it hurts, that is too hard. Try lens down, then all the sides.
Posted on May 30, 2010
  • 1170 Answers
SOURCE: Nikon S220. Lens error. turns on but displays lens
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 31, 2010
  • 94 Answers
SOURCE: my nikon s220 shows lens error and the lens remain
Clicking noises suggest the lens is either knock damaged or jamming because of sand - probably a marginal repair.
Posted on Jun 09, 2010
Lens error
can you hear a clicking sound when you put the cam on? if yes the lens is broken and needed to be fixed by Nikon. its an internal problem. try bringing it in customer help in NIkon.
May 28, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Lens error on my nikon coolpix,s220. Plz...help me to fix it!
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Jan 04, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon s220 lens error
The s220 seems to be very susceptible to lens errors, usually associated with the lens barrel being unaligned. It only takes the slightest bump/drop in many cases. Fixing it is a hit or miss solution. http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html Has a good list of possible fixes.
Jul 06, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
May 29, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon S220. Lens error. Turns on but displays lens error only.. Cannot take pics
May 15, 2010 | Nikon Coolpix 2200 Digital Camera
Lens error in nikon s220 digital camera.
Yes you right. After fall down the lens internal guide pin is damaged and thats why its happens. a912d76.jpg So visit your nearest service center for repair. Thanks.
Mar 14, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
S220 Coolpix has a lens error problem, turn camera on tries to focus (Lens moves in and out making a weird noise) but comes up with a lens error problem
Did it drop? sounds like the motor is trying to move the lens as you need, but the lens has come out of its tracking. If there is no outside damage and you still have warranty left, you should get it replaced, otherwise it means opening it to place the lens back on its tracking, but this can be tricky.
Jan 05, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Ok ive had my camera for maybe one week its a nikon coolpix s220
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Jul 08, 2009 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon COOLPIX S710 Digital Camera Logo
953 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
