Question about Garden
I have a toro lawn tractor Lx460 that won't start with the key. It can be jumped from the battery to the starter. How do i test the key module? The interlock switches are ok.
chad7houston
  • 62 Answers
SOURCE: Toro lawn tractor : tractor will not start
On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. Also, if there is a handle that engages and disengages the blades, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. The switch here could be out of adjustment or mis-positioned. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse. Also, even if the parking brake is set, you might try pressing the brake all the way down while starting, as this switch might be out of adjustment. All of the switches should be easy to locate and adjust. Also, you should check the battery. It is possible that you left the key on by mistake and drained it.
Hope some of this helps.
C
Posted on Oct 07, 2008
SOURCE: my lawn tractor will only start when i jump it at
I would have to say that this is your starter solinoid try changing that if that doesn't work it may be your wireing for the starter
Posted on Oct 04, 2009
mickey813
  • 472 Answers
SOURCE: Tractor shuts off.
IF THE SEAT SWICH IS GOOD THAN THE BRAKE SWICH IS BAD
Posted on Oct 14, 2009
97F350diesel
  • 1326 Answers
SOURCE: starter problems with sears lawn tractor
COuld be the motor or combo of motor and solenoid. They're could also be a ground/positive cable loose or have a bad connnections not allowing the full current to get to the battery. These are fairly simply systems shold be easy to diagnose...
Posted on Nov 03, 2009
  • 203 Answers
SOURCE: I have a sears lawn tractor with a Kholer courage
No, it sounds to me like it is one of the safety switches is a bit corroded, along with a battery that may not be fully charged, you are not getting enough voltage to turn the engine over. What I would first do it disconnect the battery, take apart all connections of the cables, where it mounts to solenoid, where ground cable connects to the tractor, etc. Then put everything back on. Charge the battery, or jump the tractor to get it started and let it run a bit, which will charge the battery. You may need to check wire connections that go to various safety switches, too. Under the seat, where it connects to the transmission, etc. This does not sound like a big problem at all.
Posted on Mar 08, 2010
Does a bad battery cause my tractor to not turn over?
Yes. Verify it is the battery by jumping mower off with car battery. If turns over, replace battery. If cannot turnover by jumping, try bypassing start solenoid by tapping positive cable to battery post on starter. Starter should turn. If starter doesn't turn, have starter tested.
May 31, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where is the fuse box on the toro lx 425 lawn tractor
MOST LAWN TRACTORS DO NOT HAVE A FUSE BOX. SEE IF THERE MAY BE A IN-LINE FUSE.
May 26, 2012 | Toro Garden
How to tighten belt on aToro LX460 V twin
it may have stretched and needs a new belt there is a spring tensioner that can only go so far
Apr 20, 2012 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Toro Lawn Tractor won't start, engine turns
best guess , blocked main jet or water in the carby
an overhaul would be in order
Oct 24, 2017 | Toro Lawn Mower With Toro Power Tools
HOW DO I TELL IF ITIS SOLENOID OR STRATER BAD ON MY SEAR LAWN TRACTOR?
you can check the starter by removing it and using jump cables to the body- and starter terminal to +. still there are the saftey switches in the picture when on the tractor. if you have a bad switch then it also wont start.
Jul 21, 2009 | Toro Lawn Mower With Toro Power Tools
What length is a deck belt on a toro lx460
1/2" x 90" ; Toro P/N 112-5834
Try:
http://www.tractorsupply.com/outdoor-power-equipment/mowers-attachments-accessories-parts/mower-parts/mower-belts/huskee-v-belt-1-2-x-90-in-4461290
for $19.49 if you have a Tractor Supply Company nearby.
Or:
http://www.texasmowerparts.com/catalog/products.asp?ds=DETAILED&category_id=47&group_id=184&section_id=585
# Replaces Toro 112-5834 # 1/2" X 90"
for $14.17 + $5.95 shipping
Danotex
Jul 14, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
400 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
