Question about Karcher Garden
I have a Karcher K5.86m pressure washer and the electric motor wont start. I've done the obvious like fuse in the plug etc. It was working fine one day, then got it out again and everything seems fine except the pressure pump wont start when I press the on button.
5 Suggested Answers
  • 389 Answers
SOURCE: I was using the pressure washer and it stopped
This problem, where the unit continually switches on and off when the handgun is closed, is quite common. Unfortunately it has at least six different possible causes, only two of which are easily checked.
The first thing you can do is look for leaks.  Even the slightest leak will cause this pulsing because the unit gets up to pressure, switches off, loses pressure, switches back on again, comes back up to pressure, switches off... and so on.  This repeated switching is not good for the motor and should not be allowed to continue for longer than necessary to observe what's happening.
So... 1. Does the handgun shut off completely, or does it drip? If it drips, it may simply be because a seal has failed. The handgun can be dismantled, checked, and any defective parts replaced; be sure to lubricate O-rings with silicone grease when reassembling. As a last resort, the whole gun may need to be replaced.
2. Are there any visible leaks at the high-pressure hose screw connections?  If so, most likely an O-ring needs replacing - again lubricate the new one well with silicone grease.
3. If there are no visible leaks, either from the gun or from the connections, all other possible causes are internal within the cylinder head or control head of the pump. New parts will be needed and this normally calls for a professional repair, although it's not beyond the scope of a truly competent amateur.
I hope this helps. Any further questions, just ask! Please remember to rate this response.
Posted on Apr 17, 2009
  • 92 Answers
SOURCE: Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare parts...you can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Regards,
Fulltech.
Posted on May 30, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
  • 3289 Answers
SOURCE: Karcher electric pressure washer help starting
The test / reset buttons are for a Ground Fault Interrupter built into the cord / washer. This device will help prevent deadly electric shock in the event of a malfunction - it is the same technology used in "GFI" electrical outlets located in bathrooms, outdoors, basements, etc.
You should have this serviced - or replaced before using.
Posted on Sep 18, 2015
NT48/1 professional karcher not working. Changed fuse in the plug yet still not working. Replaced the filter. Still not working. Could be the motor not working?
Is the motor running? If not, did you check the starting capacitor?
Did you check motor windings for continuity? Did the pump seize? Is electricity reaching the unit - wire ok?
Nov 16, 2015 | Karcher Garden
Sep 18, 2015 | Karcher Garden
Hi, My karcher 5.86 has suddenly stopped working. No power/ noise from washer when power is switched on. Fuse & source is obviously fine. Im going to obtain relevant torx screwdriver this week to open...
If its not the fuse in the plug it might be the on/off switch. I would check switch for continuity with a multimeter to rule it out first.
Feb 01, 2015 | Karcher Garden
After sitting for several weeks, I plugged my electric 1500 PSI unit and nothing happened. Usually there is a pulse in the motor and it waits for the trigger to flow water to reinitialize the pump. ...
this Karcher unit have a termal overload in the motor but your problem can be cause by a pressure switch the shutt on and off the motor when you stop spraying.
Aug 15, 2010 | Karcher K2.26 Electric Power Washer
Karcher K2.36 Pressure Washer I've just fired up my Karcher for the first time since last year and the motor started running fine, I then switched on the tap to allow the water through and the motor cut...
The water must be switched on, and seen to be running freely from the nozzle for a few seconds before switching on the power - suggest you check the fuse in the plug, and then try the above.
Apr 17, 2010 | Karcher K2.26 Electric Power Washer
Karcher K4.97M electric waterblaster cycling
It sounds to me like the unloader valve is bypassing internally.
Nov 16, 2009 | Karcher K2.26 Electric Power Washer
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Karcher k3.48 pressure washer appears to be seized up?
if the machine is blowing fuses then it could be the motor! if not then maby the start cupasitor has failed
Jun 01, 2009 | Karcher PSI Electric Pressure Washer
My karcher hds 745 has started blowing fuses. it switches on the power light comes on and it makes a buzzing noise for about five seconds and then blows the mains 13amp fuse. i have replaced it twice but...
you have an electrical short in the motor windings. you'll have to either replace the motor or buy another washer. also check to see if the motor isn't locked up with a piece of trash. to do that you'll have to dissassemble housing until you get to the motor. it should turn easily by hand. if so you have a short.
Apr 19, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
327 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
