Question about GE XL1800 1100 Watts Microwave Oven
Glass inside does not rotate now - GE XL1800 1100 Watts Microwave Oven
    President:
  • 949 Answers
The problem is typically the turntable motor, it is accessible by first disconnecting the power then removing the lower panel that houses the filters and lights. You will see a small device with 2 wires that looks similar to this
Glass inside does not rotate now - b162a2f.jpg The next most common thing to fail would be the coupling that attaches to this motor and sits inside the oven, you can take the glass tray out and lift the coupling, check for cracks or breaks, try running the microwave for a few seconds without the table and see if the coupling turns with the weight of the table on it. This may indicate a stripped coupling.
The 3rd component and most expensive to fail is the control itself, there is either a relay or diode on the control that sends a signal to the motor to turn. You should verify that you have power to the motor before replacing it.
I hope this helps
Posted on Apr 25, 2010
What size glass tray do I need for my Westinghouse model WCM770B/W microwave? I broke mine and cannot find the answer in the manual.
Frequent thrift stores or yard sales, or take a tape measure to the inside of the microwave
. If your dish was square, the glass plate should likely be about 1 inch less wide and 1 inch less deep that the inside of the box.
If you have a round plastic rotator, the dish should be about 1 -2 inches bigger in diameter than the plastic rotator.
God bless your efforts.
Oct 23, 2017 | Westinghouse Microwave Ovens
Oven inside glass pan does not rotate
the motor that causes the rotation of the glass has failed
Oct 08, 2013 | LG Microwave Ovens
I'm experiencing occasional arching from the center of the oven i.e. out of the spindle that rotates the metal rack and glass turntable. I cleaned thoroughly and it seems to have minimized the proble
Its unlikely to be associated with the tuntable motor. Units are tuned to prevent arching. Therefore it appears something may have changed inside the unit. Be sure there are no loose items or bits of foil or other mateallic items inside. Also check metal turntable.
Dec 31, 2011 | GE Advantium 120 Convection/Microwave Oven
Hearing sound from inside when it is switched on ,some time the glass turn table doesnot rotate
Either your turntable motor is going out or your turntable guide is not aligned properly or seated propertly when then glass is on top of it.
Oct 09, 2010 | Microwave Ovens
The glass plate will not rotate when trying to heat up your food...
Sounds like either the turntable motor has seized or that the shaft of the turntable motor has broken off inside the roller ring. You may need to chek with your local De'Longhi repairer.
Nov 29, 2009 | DeLonghi Microwave Ovens
Jenn-Air JMC8100- Microwave
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 05, 2008 | Jenn-Air JMC8100 Microwave Oven
Model je1651 glass table inside does not rotate during operation. the glass is properly aligned on the wheels and the three armed support is properly aligned on the center pivot. what do i do to get the...
Is the spindle that the glass tray rides on rotating? If not, you may have a defective turntable motor. You will need to remove the bottom panel of the oven to access it. Repairclinic.com carries the part, but you will have to provide a more complete model number in order to narrow down the correct part. There are several model ovens listed with the model number you provided. You may also check with searspartsdirect to see if they carry the motor. The two websites have competitive pricing and sometimes the parts are cheaper at one website or the other. Post back if you need further guidance. If I'm wrong with my assumption, I will try to give you beter advice. I hope this may help you.
Apr 07, 2008 | Microwave Ovens
Kenmore elite 721.80833 microwave
I purchased a later model glass tray which was redesigned and now it works fine.Just take your tray to the store and compare it to a newer one and you will see the difference.
Oct 20, 2007 | Kenmore 80803 Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
108 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
