Question about Hoover HW130M Front Load Washer / Dryer
When my washer/dryer is turned off, why does the drum keep filling with water?
  • Hoover Master
  • 43,501 Answers
Turn the water off in the back of the washer where the hoses hook up...
Then check this tip out...
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Posted on Apr 26, 2010
My drum fills with water and is not turned on
Sounds like water control solenoid is stuck in the open position.
The hot and cold solenoids are located just inside where the hoses attach to the washer.
Feb 28, 2015 | Frigidaire Affinity FAFW3801LW 27"...
Water fills when off
you need to replace the water inlet valve. most machines tell u to turn water off to washer when not in use. what a pain that is
Apr 06, 2014 | LG WM3431 Front Load Washer / Dryer
Water continues to fill into the washer drum on the spin cycle.
Hi
You could have a stuck solenoid valve
Try this: Set the water temp on cold. Turn on only the hot water.
Does hot water try and fill the drum?
If so then there is a problem with the hot solenoid.
Next set the water on hot. Turn on only the cold water. Does cold water try and fill the drum ?
If so then there is a problem with the cold solenoid.
Jan 05, 2011 | Whirlpool LTE6234D Top Load Stacked...
The drum in the washer/dryer keeps filling up with water when the machine is turned off. We've only had the machine about 18 months
If you are inside the warranty time, don't do anything or break any seals. Instead report your dealer about the same. Else you can ask a company man or local professional to repair your units board.
Aug 07, 2010 | Hotpoint Aquarius WD63 Front Load...
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
Water keeps running.......
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
May 19, 2008 | Frigidaire FEX831CS Top Load Stacked...
Re EW1200i : drum keeps filling with water
is it overfilling? if so you have a problem with the pressure side of the system and it would need cleaning out.
May 26, 2007 | Electrolux EW1200i Front Load Washer /...
Hoover HW130M Front Load Washer / Dryer Logo
52 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
