Question about GE HSS22GFT Side by Side Refrigerator
Not staying cool - GE HSS22GFT Side by Side Refrigerator
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezernot staying cool - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 27, 2010
Ba falcon cooling fan stays on after ignition turned off
Typically there is a delay and the fan stays on tell the engine is completely cool.... if it stays constantly on then the relay for this fan is bad...
Feb 22, 2015 | Cars & Trucks
Fridge won't cool on AC, the pilot will light, but will not stay on. Dometic rm2352 will not cool at all
Sounds like you have several issues. One, the flame not staying on is probably due to the igniter not sensing the presence of the flame. Clean the end of the igniter and make sure that the gap between the tip of the igniter and the flame tube is approximately 1/8". If this does not correct the issue then the flame not staying on and the cooling may be the result of a bad board. If it does stay lit and still does not cool then you may have a bad thermistor. To the bottom left of the refrigerator you will see a black covered circuit board. Remove the cover and to the upper left of the board you will see two harness plugs. Unplug the lower harness that has two wires in it and let it run for 24 hours. If is does not cool down then you have a bad cooling unit. If it does cool down then you have a bad thermistor.
Jan 29, 2014 | Dometic RM2652 Refrigerator
Where is the relay located for cooling fan of 2005 chevy suburban
in the 2005 suburban, the cooling fans will stay on after the vehicle is off if it is too hot to try and cool down the engine
May 17, 2012 | 2005 Chevrolet Suburban
Fridge is not staying cool after defrost--only stays cool for a couple of days then stops cooling until we defrost again
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Is it normal for 1997 cadillac deville to stay at 220-226 temp.
No,it is not,the temp should stay about 200 to 212,if the cooling fans are staying on,and not going off,then the cooling system has a problem,change the thermostat,and bleed the air from the cooling system.if this does not help,change the coolant sensor out with a new one.
Aug 16, 2010 | 1997 Cadillac DeVille
Whay does my radiator fan stay on whaen i turn the car off
It stays on to continue cooling the contents of the radiator, which remain hot even after you turn your car off. When the coolant is cooled, the fan will turn off.
Aug 07, 2010 | 2001 Nissan Altima
LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Oct 21, 2009 | Whirlpool RCC3024 Electric Cooktop
Why is my engin cooling fan staying on?
check and replace the engine cooling fan relay, refer to the owners manual for location under the hood.
Sep 27, 2009 | 2004 Mitsubishi Endeavor
Cooling fans
how long does it stay on?? electric fans have a thermostat and can keep running after your car has been turned off
Sep 19, 2008 | 1991 Toyota Celica
GE HSS22GFT Side by Side Refrigerator Logo
70 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
