GEM SOUND PA-750 POWER AMP
HI! I just purchased a GEM SOUND PA-750 power amp (used) on ebay,recieved it this week,but it came without a manual to it.I been working on cleaning it up,and noticed a wire not soldered to a switch,that controls either to put it in bridge mode,or stereo mode.I don't have any clue to witch yerminal it goes to??? so I was wondering if there was a manual I could get to help me locate the right terminal???? Thanks Mark P.
  • 52 Answers
Hello plumer,
Locate a small slide switch at the back panel of your amp.
3 terminal and if you've snapped one of the wire, you'll see where the wire goes. But if it is 2 wire and using a ribbon type, follow the arrangement of the wire. No harm to the amp if you make a mistake. if bridge, all power will be shifted ti the left channel.
Good luck,
Posted on Apr 29, 2008
Gem sound pa 650
Same size that are already fitted.
Aug 18, 2014 | Gem Sound Audio Players & Recorders
Gemsound xp-550
A diode/rectifer or voltage stabliser, or leaky capacitor in the power supply.
Also the main transistors in the power amp or if it has an output IC - that!
If you can in anyway disconnect the power supply section from the amp circuit, you can isolate which part is faulty. For if it blows when disconnected from the power amp, you know it's just the power supply that's gone. And if it does not blow - then it's the amp!
Aug 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Gem sound exa 3950 amp
Hi...
If it's a straight-up power switch then it will need to be replaced if it works off a relay then the relay is gone.
website
http://www.gemsound.com/contact.html#
Mar 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Klipsch sub 10 keeps blowing fuses
More than likely the power supply switching transistors have fried. Also check the large caps in the primary side of the power supply. If you don't know what your are doing do not attempt to fix the power supply.. very dangerous voltages involved !!! Send it to Klipsch for repair or purchase a Bash replacement panel http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-750
Jan 17, 2009 | Gem Sound SUB-650M Speaker
Boost volume of computer
HI...
Connect the "line-out" of the sound card to the "Line-in" of the GEM amp
Dec 26, 2008 | Gem Sound GemSound PA-585 2-Channel...
Gem Sound clipping problem
First of all the EXA-3940 is rated at 350watts per channel in to 8 ohms. The 1400 watts is bridged into a 4 ohm load. Second, the speakers can handle 1000Wats peak with an average of 600 continuous (i'm guessing). That tells me that the amp is underpowered for the speakers. The sensitivity of the amp is such that the mixer is overdriving the input stage. That is what is causing the clipping. If you are looking for more volume, you are probably better off purchasing another amp and running them in bridge mode, 1 per speaker cab. Be careful though, not to overdrive the speaker cabinets either.
Dan
Sep 21, 2008 | Gem Sound GemSound PA-585 2-Channel...
Manual
Contact Gemsound thru their email.
Sep 04, 2008 | Gem Sound GemSound PA-585 2-Channel...
Gem sound xp-350 clipping
Hi There,
You have given me a good clue to your problem....
You say that the CD player goes well and does not shut the system down like the Live connections. This is a single input configuration...
This means that there is sound levels coming in from the live multiple connections that are too strong (Loud) for the amp to handle...
Its a good amp you have as its shutting down to protect itself instead of blowing up....
So.... set up for the live show then disconnect all but one of the live inputs and start the live session if its OK, then connect another of the live connections, and see if its OK, if it is then connect another live one connecting each one progressively until the problem occurs again...this last live connection is the one that is too loud in signal strength for the amp to handle causing the shut down...
Solution is to reduce tha signal on that last cable source to a level that stops the shut down...I remember that groups of guitar players have volume controls on each guitar and if these are set too high then this can occur....specially if they are all using the same amp without a controlled "mixer man" monitoring each input signal.
Rember the small meters on the mixing panel which have a green painted area and a red painted area the "mixer man" must keep the each meter needle in the green zone for all the inputs otherwise a shut down occurs.
Hope this helps you...
Cheers From
YUBEUT
Oct 26, 2007 | Gem Sound GemSound PA-585 2-Channel...
657 people viewed this question
 Grubhead
Grubhead
