Question about Nintendo Wii Console
Internet connection I am trying to connect to the internet on our Wii and I get an error code 51330
    Genius:
  • 1,234 Answers
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Posted on Aug 27, 2010
Tip
Nintendo Wii Error Code 51330 usually indicates that the WEP/WPA key you set on...
<span><span style="font-weight: bold;">Nintendo Wii Error Code 51330</span> usually indicates that the <span style="font-weight: bold;">WEP/WPA</span> key you set on your Wii is not the correct one to gain access to your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>router</span></a>. <br /><br />When you setup a router for wireless internet, you usually set a WEP key or by default one is set. This is basically a <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>security</span></a> key(<span style="font-weight: bold;">password</span>) that you set so any device that wants to use your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>internet</span></a> has to enter correctly in order to gain access.<br /><br />If you know your router security key, go into your <span style="font-weight: bold;">Wii network settings</span> and make sure it is entered correctly. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> to read my tech article on how to configure your Wii's network settings. <br /><br />If you do not know the security key of your router, then read my other article by clicking <a href="/../support/r9359087-find_wep_key_router_router_security">here</a>. This article will go over <span style="font-weight: bold;">how to find the router security key</span> or if need be, set one.<br /><br />Be sure to check out my other <span style="font-weight: bold;">Tips</span> by clicking on my profile name and then clicking "<span style="font-weight: bold;">Tips</span>" at the top left. <br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /></span><span style="font-weight: bold;">Nintendo Wii Error Code 51330, error </span><span style="font-weight: bold;">51330, Wii </span><span style="font-weight: bold;">51330, Wii error </span><span style="font-weight: bold;">51330, Wii network settings, can't connect Wii to netflix, Wii netflix, Nintendo error code </span><span style="font-weight: bold;">51330, Wii code </span><span style="font-weight: bold;">51330</span>
on Jun 14, 2011 | Nintendo Wii Console
Error code 51330 on wii
They have stop the Internet connection for what reason ikke dont knowhow maybe use IT og wii u
Oct 12, 2014 | Nintendo Wii Console
I am trying to connect Netflix to my Wii and I keep getting error code 51330 and 51331. I don't know what these errors are. I am trying to set up with wireless internet.
From Nintendo:
Error Code 51330, 51331, and 51332
    It appears that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console. Click here for more information about WEP and WPA security, including how to access the settings for your Access Point.
If your wireless network password isn't wrong, reply. Hope this helps somewhat.
Jul 21, 2011 | Nintendo Wii Console
I am trying to watch a movie on net flix, however everytime I tried to look for the internet service the following error comes up: Error code 51330 is unable to connect to the internet.
Hi there!
Error code 51330 on the Wii means that the password you entered into the Wii to set up your internet was entered incorrectly. You will need to go back into your internet connections settings menu on your Wii and enter the correct password/security key for your router. Please remember the security key is case sensitive.
Hope this helps!
Jul 05, 2011 | Nintendo Wii Console
I received an error code, 51330 when attempting to go online with the WII console for the first time.
Hi there!
Error code 51330 on the Wii means that the security key you entered into the Wii to set up your internet connection was entered incorrectly. You will need to go back into your internet connections settings menu on your Wii and enter the correct security key for your router. Please remember the security key is case sensitive.
Hope this helps!
I tri to connect internet error code 51330
Error code 51330 is trying to tell you that the Wii Wireless Adapter cannot connect to your wireless router. The most likely reason for this error is that the password you entered is not typed correctly, or that you forgot to type one in at all. Remember that security keys are always case sensitive.
Jul 01, 2011 | Nintendo Wii Console
The wii will not connect to internet. it tell me error code 51330
I am sorry to hear you are having problems with your wii's internet. Error code 51330 has to do with configuring your security settings on your wii. It means you are trying to use an encryption method that is not allowed by your router's wireless internet. Make sure you have set up your internet profile with the right encryption method (WEP, WPA for example) and correct encryption key/password.
You can check Nintendo's official support article for this error number here:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Apr 29, 2011 | Nintendo Video Game Consoles & Games
Error code 51330
That's usually a problem related to wireless security. You'll want to try to make sure your computers can connect to the wireless--or see if it's working or not.
If everything is good. Make sure the password you have on your Wii to connect your console to the wifi is good.
That should work... if not, reset your wifi settings and try again!
Feb 08, 2010 | Nintendo Wii Console
Nintendo Wii Console Logo
49 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
