Question about Acer Aspire 5100 Notebook
Wireless network Daughters Acer Aspire 5100, with windows XP home has two wirless networks showing. Both icons show signal excellent and present to the computer but we can not go onto explorer. Yet when cable is attched there are no problems. can you offer any advice please
    Genius:
  • 3,587 Answers
Sure..it's most likely due to a browser configuration issue in Internet Options..open that up, and make sure that the wireless is one of the choices..should clear it up
Posted on Mar 23, 2008
I lost the wireless network access to internet. The router I use connects my other computer perfectly to internet. Acer recognizes "excellent signal strength". Please advise how to re-establish...
Hi
could you tell us what operating system you are running please is it xp or vista or windows 7
it would help us to guide you in the right direction
thankyou
Feb 17, 2011 | Acer Aspire 5100 Notebook
Keeps dropping wireless network
I had the same problem. My solution was calling my internet service provider to see if the modem was reading. It turned out that it was fried. Once we got the new one set up, everything went/is going smooth.
Apr 30, 2009 | Acer Aspire 5100 Notebook
How to connect to a wireless network in Windows Vista acer 5315 - router name is show but not connect help me plzzzzzzzzzzzzzzzz
0. Check if your wifi module is turned on by switching on a hardware switch on a border or back of your laptop.
1. Click once on right bottom corner on icon with two monitors.
2. Choose connect to network.
3. Choose one of access points
4. Enter password
Mar 21, 2009 | Acer Aspire 5100 Notebook
My daughters acer one will not connect t the internet and there is no connection icon in the system tray can anyone help
Right Click on "My Computer"
Select "Properties"
Select " Hardware" tab
Click "Device Manager"
click the "+" sign network icon
check if the wireless card is there.
if you see the wireless icon..
then Go to Control Panel
select Network and Internet connection
Select Network Connection
then Right Click the wireless connection ( menu will pop out)
check if the wireless is Enable
to restore the icon to the desktop: select properties after the instruction above
on the general tab
check the " Show icon notification area...
Check "notify me when......
Mar 15, 2009 | Acer Aspire One PC Notebook
Wireless connection
hi..In your notebook it will automatically detect
the wirless device once u come across your
range.
check this out..
thank u..
rate me..
Feb 09, 2009 | Acer TravelMate 240 Notebook
The wireless icon has vanished on my acer aspire one netbook and i cant get online
Go to Start/Settings/Network Connections. When the window opens right click on the Wireless Network Icon and select Properties. In XP there should be a check box to allow display of notification when connected. If some other OS, hold the right button down on the Icon and drag it to the task bar. It should drop an icon for showing the status.
Before doing all of this, is there an arrow to the left of the icons? If so, click on it see if the Icon is simply hidden.
Jan 17, 2009 | Acer Aspire One PC Notebook
Can not connect wirelessly with router
The list of wireless routers that are available in Windows is very limited and the signal strength of any router that is detected is weak. This can occur when the Lite-On USB Wireless 802.11 b/g hardware and Windows are not able to fully synchronize the signal strength data. Figure 1: Example of detected wireless devices when the antenna cable wire is connected to secondary port c01153759.jpg Figure 2: Example of detected wireless devices in the same environment when the antenna cable wire is connected to primary port c01153760.jpg To correct this error , download and install Lite-On USB Wireless LAN Driver Update (sp35177) (in English) from the HP Web site. This update should only be applied if your PC has the Lit-On USB Wireless LAN adapter and is exhibiting the symptom. As a work-around, you can connect the wire that runs from the wireless antenna port to the primary port on the cord as follows: CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Open the side panel.
  2. Find the wireless networking board by following the antenna wire connected to the wireless networking antenna port on the back of the computer. Figure 3: Wireless networking hardware c01153761.jpg 1 - Wireless network board 2 - Antenna wire 3 - Wireless networking antenna port
  3. Very carefully, disconnect the small wire from the board by gently pulling the end of the wire away from the board.
  4. Connect the wire to the other available port on the board. Figure 4: Available port c01153762.jpg
  5. Replace the side panel, connect the power cord, turn on the computer, and use the computer again to verify that wireless signal strengths have improved.
Jan 14, 2009 | Acer Aspire 4520-5582 Notebook
Wireless connection problem
If you're using windows xp, download official driver from :
http://www.drivercabinet.com/acer-aspire-one-driver-downloads-for-windows-xp-atheros-wireless/
all windows xp driver for acer aspire one also available on that website, take a look at the related post at the bottom of the post.
Nov 01, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
