Question about Dishwashers
My Zanussi DS17 slimline dishwasher is leaking from below the door at the front. The inside seals all seem to be fine, but the catchment moulding below the door (which is revealed at the front when the door is opened) is filling up with water, and then overflowing. I can't see where the water is comming from, but it is definitely the water from the washing cycle as it's hot. Any ideas? I haven't dragged the maching out from the wall yet, but I may have to. David R
  • 269 Answers
Have a look at the bottom spray arm and check the ends of the arm for splitting as this will cause the water to be directed at the door lower section and leak.Try taking arm out and run for a short while and see if it stops the leak.If still no good check that door is closing fully.
Posted on Jun 03, 2010
Testimonial: "He has got it spot on. We got an engineer in, and he replaced the bottom spinner, which was indeed split at the one end. Apparently this stops the spinner spinning, the water then sprays continuously against the inside of the door, and floods down to the bottom, causing the overflow. Apparently the door is not actually watertight, but the intermittant spray when the spinner is spinning correctly is not enough to cause the flooding. So simple, and yet so expensive. The engineer call out and return visit cost £80, the replacement spinners £19. If I'd known this in advance, I would have just bought the spinners, which are easy to fix in a couple of minutes, without any tools. David Rennie "
Black mould
this is the fatal flaw of front load washers, see this complaint over and over, use bleach to clean it or Tilex mold and mildew remover, make sure the hole that drains the seal is clean.
May 13, 2010 | Zanussi ZWF1440 Front Load Washer
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
Mar 20, 2010 | GE 24 in. GSD3330C Built-in Dishwasher
Two problems: soap cover and seal?
Door leaked because of a plastic bearing ($4.10 part) on the lower arm causing water inside to surge and splash out the vents on the bottom of the door. Soap cover problem was a corroded spring caught on a plastic part inside the door panel. The spring actually broke and now seems to work fine because there was another spring helping to do the same job that is now allowed to work.
Dec 08, 2009 | Whirlpool DU943PWK - Multiple Color...
My 1998 GE dishwasher leaks. Into the floor, now I see stains on the ceiling below. What to check? Door seal is fine. The dishes get washed. Pressure is good to go. No water out of the front of...
check the water connection at the valve to the dishwasher. If the dishwasher only leaks when used then the motor seal is damaged. If leak is constant the the leak is at the supply to the dishwasher from the water supply at the valve
Good Luck
Dave
Aug 27, 2009 | Dishwashers
How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
May 21, 2009 | Refrigerators
Whirlpool dishwasher leaks
Just about all dishwashers will leak a little around the door seal over time but should not leak to the point of wetting the floor. With the door open, check in the front of the tub, under the door. Lots of gunk? Clean this area out well plus take a soft damp rag and clean the door gasket while feeling for any damage. Then go along the mating surface of the door and look for any nicks. If it leaked all the time I would suspect the door hinges have been sprung. Hope this helps, Ken
Apr 26, 2009 | Dishwashers
Rubber door seal mouldy
Wouldn't normallyexpect a few mould spots to leave that bad a smell, so likely you've got two distinct issues.
Starting with the water trapped in the seal: Open the door and very carefully slip your fingers into the seal where the water is gathering (to stop your hand getting trapped between the drum and the outer casing, put your other hand inside the drum and push it up out of the way - just be careful not to let it spring back too fast).
At the very lowest point,of the space inside the seal, either at the very front or the very back (so tucked into the corner between the floor of the seal and it's front or back wall), you'll find a little drainage slot. Once you've cleared the inevitable blockage from this slot, your seal problems should vanish.
If the foul smell is coming from inside the machine, the problem is likely to be grey sludge inside the works of the machine. This is usually caused by modern detergents not being quite as good at working at 30 degrees as they claim to be. The answer is to run a cycle every now and then with no laundry, detergent, or conditioner in the machine, on the longest, hottest programme the machine will support. This should be sufficient to dissolve the rotting sludge and pump it away down the drain.
A.
Apr 06, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi front load washer door seal
Keeping the door open after your wash would help in keeping the interior dry. Do not push the door shut, just leave slightly open. Only before you begin your wash, check to see your cat is not inside.
Oct 13, 2007 | Zanussi FJS1225W Front Load Washer
Dishwashers Logo
158 people viewed this question
Top Dishwashers Experts
Owen Barnes
