Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
I have a bissel proheat carpet cleaner. THe trigger is stuck in the on position. However, no water or shampoo is coming out. I can pry it back out but it feels like a spring is missing or something like that.
  • court2court Apr 25, 2010
    i have a bissel proheat carpet cleaner model #7950. It is brand new. After one small room, the trigger got stuck in the depressed position and the spray was not working. I can pry it up, but it acts like a spring is missing and biggest issue is that no spraying is happening. Someone else posted a "it is broken and you need a new part" which was helpful, but is there aquick do it yourself fix?
  • 643 Answers
You may need to replace the handle assembly, or at least take it apart and reconnect the spring inside the handle..
here is the repair manual, which has good illustrations on page 9 and 22 of working on the handle..
http://newzealand.bissell.com/images/includecontent/service_center_help/upright_deep_cleaner_repair_guide.pdf
Posted on Apr 25, 2010
  • 4,924 Answers
Yes..if it does that it is broke ..and it needs replacement...
I will link here to a list of parts diagrams for Bissel...on the end of the page you will find some Profeat models...I didn't know exactly which one ...(there are 3 or 4 models) so I will let you choose from there ...
when you click on diagram it will show you a scheme with all the parts numbered and a list with prices...and possibility to by ...locate the part ..and choose it from the list ..
Good luck !
I have a pro heat turbo cleaner and the water does not come out when the trigger is depressed
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 07, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
WHERE DO YOU PUT THE SHAMPOO IN THE PRO SHAMPOO MACHINE THERE IS A CONTAINER IN THE BACK AND THERE IS THE WATER BAG IN THE FRONT SECTION
The shampoo solution goes in the back container. The clean water goes in the water bag in the front section.
If you need parts you can find them below
http://www.usavacuum.com/category-s/387.htm
Make sure to give positive feed back.
Thanks. USAVACUUM.COM
Mar 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The water and shampoowon't come out but it cames
This model is famous for burning up the silinoid switch that allows the water to come out the bottom to clean the floors. That will need to be replaced, but my recommendations is to take this model back and bet your money back. It is engineered bad!
Nov 25, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell proheat does not pump outwater into carpet
Remove the water tank and shampoo dispenser, unplug the machine, turn it over and check for any obstructions, carpet fluff or pet hair is usually the problem. Hope this helps.
Oct 04, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
NO WATER COMING OUT FOR SHAMPOOING /DUMPS WATER WHEN UPRIGHT
there is a belt inside that runs the pump to spray the water. I would take it in a have it replaced. Mine did the same exact thing.
May 25, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Oct 20, 2008 | Bissell 9200 Upright Vacuum
Bissell PROheat 2X shampoo carpet cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=565019
Bissell ProHeat 2X shampoo carpet cleaner
Posted by boomerboo on May 02, 2008
I don't have the instruction for this machine; if you could help me with were to put the water and cleaning solution and how much. Thank you, Sharon my email address is sharonlee326@yahoo.com
Comment by boomerboo, posted on May 02, 2008
I need direction on how to use the shampoo carpet cleaner
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 9500 ProHeat 2X Clean Shot Upright. The best place to get the owner’s manual for the Bissell is to check the Bissell website or to call the Bissell factory or manufacturer and give them the Model # of your unit and they will mail you out one. Always use genuine Bissell products made for the model that you have for best results. So check with your local factory authorized vac dealer that carries and services Bissell. I will give you the Bissell factory phone # listed below for further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
79 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
