Question about Akai LCT2701AD Television
Tv is not turrning on manually or by factory remote and cable remote works sporadically
  • 10 Answers
Power supply capacitor array on the power output side have become bulged and are starting to leak. This is one cause for the power supply to be unstable and unable to provide appropriate power to the LCD
Posted on Apr 25, 2010
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
Why doesnt any remote work with the tv? I have to use the buttons on the tv to control the power and volume
Maybe the batteries in the factory remote are dead or in backwards. I would start there.
Jan 21, 2015 | JVC JLC37BC3002
I have a Panasonic 26" LCD TV Model TC-26LX60 that no longer has any audio, the volume doesn't work nor the mute. It DOES work only sporadically and this is how I know the volume nor mute doesn't respond....
Try connecting your source device to another TV using the same cable to see if the audio works there. If it doesn't, the issue is either your source device or your cable.
Aug 07, 2013 | Panasonic Televison & Video
I have a panasonic viera and it is stuck on the PC channle and wont change how do i change it or restart my tv entirely?
Are you using the remote's AV button or the AV button on the TV? Do the other buttons on the TV work? (If the control board has failed, then the remote won't work nor will the input button.)
Are the cables for other devices connected and were the devices connected and off when the TV was turrned on? Are they on when you try to change the input? Bad cables may limit the sources the TV will allow you to select. Some will not go to an input that isn't providing any signal.
You can try resetting the TV to the factory specifications (you'll lose the channel programming though). Press Menu > Setup > Shipping Conditions
The manual is available here: http://www.retrevo.com/support/Panasonic-TX-32LX70-TVs-manual/id/2920dj480/t/2/ if you need it.
I hope this helps.
Jan 01, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have a Toshiba regza LCD 32AV600 TV set. The remote is not able to turn on the TV (only manually from the side of the screen). Other functions of the remote work fine. I tried using a different remote...
Tries reset the tv back to factory setting and the cable box too by unplug,replug it back an hour later.Go to tv menu,go to PICTURE,go down to reset,so the Tuner board it reset it back to the factory setting.This should solved ur problems,not than the tv tuner board that recieve the bracasting signal board have probems.
Jun 02, 2010 | Toshiba 32AV600E 32 in. TV
The cable guy programmed the cable remote to turn on/off the TV. We used it to turn the TV to stand-by. Then pushed the power button on the TV to turn the power off. Haven't been able to turn the TV on...
First use the original remote control that came with your tv, or just manually turn it on at the tv itself to bes sure it is working. If it works you should call the tech support for the cable company to program their remote control to a different code - or put it back to to factory state and just use two remotes.
Sep 12, 2009 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Volume does not work
check for loose solder and the system ic
Jul 17, 2009 | JVC HD-52G787 52" Projection Television
The remote control works sporadically and when the TV is turned on or is bumped, the menu and volume displays flash on and off on the screen. What can I do to fix it?
NO, your remote control sounds like it is sending the signals to the TV. Take the batteries out or put it in a drawer to test. If it's the TV doing it itself, then it's a bad remote receiver circuit.
Jun 30, 2009 | Philips 32PFL6704D 32 in. LCD TV
Ceiling fan
If the switch is "OFF" on the wall, the remote will not control anything. The power has to reach the receiver first. If it worked before you turrned the swich off, than one of two things. Either
A: You blew a circuit to the unit or
B: Your receiver went out.
First thing I would do is check that POWER is getting to the receiver.
Sep 06, 2008 | Universal Remote Control Hampton Bay...
Codes for sylvania tv
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
Feb 10, 2008 | Zenith ZEN450 Remote Control
Akai LCT2701AD Television Logo
144 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
