Need a manual for Realistic 32-1100A Mixer
Need the owners manual (w/circuit diagram) for Realistic 32-1100A Stereo Mixer
water damage ''returned'' my original to PULP!! ;-(
TIA for any help
chiquititas
  • 1010 Answers
SOURCE: help replacing stereo in my 2000 jetta glx
REMOVE FUSE COVER ASHTRAY AND LITER AND THEN REMOVE TWO SCREWS ONE THE TOP OF THE PANEL HOUSEING AND TWO SCREWS ON THE UNDERNEATH INSIDE IF THE ASH TRAY AND IF INSPECTED FROM UNDERNEATH PRESS BACK THE TABS AND STEREO IS OUT
Posted on Jul 01, 2008
SOURCE: i need an origenal owners manual for my jensen
www.audiovox.com/manuals/owners/vm9510_manual_final.pdf If i'm not mistaking, this is the closest thing that i could find for the Dual 8180 also
Posted on Feb 28, 2009
petraman7
  • 1175 Answers
SOURCE: Hello, i have Stereo mixer model 32-1100 A by
http://support.radioshack.com/productinfo/
Hope this helps,
Scott
Posted on Apr 08, 2009
  • 9 Answers
SOURCE: craftman sabre saw manual model 315-172100 or copy of original ok
Go to sears parts website and it guide you through to enter your part number and it will show you a parts diagram and how to order as well
Posted on Jun 14, 2009
  • 44 Answers
SOURCE: Vt Holden Commodore stereo wiring diagram
head down to your local auto store and you will be able to pick up a wiring harness adaptor. you wire your stereo to this adaptor then you simply plug it into the wiring loom. no damage to the loom so if you ever need to reinstall the standard stereo its just an unplug and plug back in. its extremely simple and colour coded so there are no mistakes.
Posted on Jun 28, 2009
I need a new channel changing Mike for a Realistic TRC 476. The cord for the Mike was cut and even though repairs were done the radio just scans through every channel very quickly and constantly.
You should check the new cable wiring connections. There is a resistor in that microphone that connects to the channel button circuit, it is (electrically) between switch 5 (up) and pin 3. If this not present then it may be causing your issue, IT is also possible that the diode for that circuit (located on the main board) got damaged when the cord was cut. diagram: http://www.cbtricks.com/radios/realistic/trc_476/476_print.htm
Oct 10, 2016 | Radio Communications
I am desperately looking for the owners manual for my 1974 model Realistic sta 220 stereo receiver. Thank you in advance.
hi, I have just done a search for realistic sta 220 manual and lots of results are thrown up, you need to try this as there so many results for the query.
I used bing rather than google.
May 30, 2015 | Audio Players & Recorders
Studiomaster manual
On the rear panel there are two jack socket marked: Left and Right Insert.
These are connected to the graphic equalizer using two insert cables, one for each channel ( L & R). The cables have a stereo 6.35mm jack plug which plugs into the mixer, the cable splits into two mono jack plugs marked tip (or send) and ring (or return). The send (tip) connects to the input of the graphic equalizer and the return (ring) connects to the output of the graphic equalizer. How it works: The stereo jack interrupts the signal in the mixer and sends it to the equalizer, the equalizer processes the signal then sends it back to the mixer. Typical cable is shown below. If the equalizer has a different type of socket, phono for example you will need jack to phono adapters or insert cables with suitable plugs. Hope this helps.
Apr 05, 2014 | Audio Players & Recorders
Can I connect only one speaker to a yamaha emx 312 sc power mixer?
First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
Just my opinon.
Link to Yamaha EMX 312 Owner's Manual:
Yamaha EMX Series Owners Manual
Dec 06, 2013 | Yamaha Music
I need a d104 wired to 5pin DIN for a realistic base
The astatic diagram "may" still be pasted on the base of your microphone inside. If not, here is a link to an image of what it should look like.
http://www.qsl.net/wa2mzf/d104-a.jpg
Not knowing which Realistic base you have, I suggest the Radio Shack Website to download a copy of the model number as they have support for almost everything they sold. Their manuals always had circuit diagrams. Unles they changed their policies, they should have something. http://www.radioshack.com/search/manualResults.jsp?kw=product+support
The only reason I give the link is because the Realistic CBs were made by a number of companies. If you have the old microphone for the base you can open that up and find the comparable connections to the sheet, .
Jan 15, 2012 | Radio Communications
1996 Toyota Rav4 setero wiring diagram
If you don't have an owner's manual for your Rav4, look at your local library or online. Car manufacturers have circuit diagrams in their manuals.
Jul 13, 2010 | Buck Toyota Rav4 2003 Stereo/radio...
628 people viewed this question
 Grubhead
Grubhead
