Screenduo instalation when i run the driver i get to the screen that tells me to connect the screenduo and cut it on when i hit next it says the driver is updating but it sits here for hours not updating and wont advance to the next install promp
  • patz78 Mar 25, 2008
    the screenduo that came with my asus motherboard
  • Anonymous Nov 18, 2008
    I have this problem too.....exactly.
    President:
  • 2,351 Answers
Answer this. You are installing a driver. (got that part). Driver is for what component?
Posted on Mar 24, 2008
I had a MP 160 Canon printer in 3 how do I install it on my laptop
install the cd or find the drivers online follow installation procedures and put usb cable.......... there you are!
Jun 30, 2016 | Canon PIXMA MP160 All-In-One InkJet...
Intermittent Cruise Control Issue - cuts out when small bump in road is hit and may or may not re-engage after that.
Check the wire connector that plugs into the cruise control under the hood. Sounds like a loose connection. Remove the and reinsert the wire connector several times to make a better connection. Stepping on the brake pedal disengages the cruise control by a switch on the brake pedal, not the computer.
Jan 09, 2016 | 2004 Buick Rendezvous
How do you reload dell drivers from a cd from the second you turn your computer on? My friend recently dumped my computer and reinstalled the windows os. I dont know how to reload the drivers from the cd....
use the bios, go into the bios and tell it to boot from the cd rom, then stick the cd in and hit save and exit, later you'll need to change it to boot from the hdd
Sep 18, 2010 | Dell Inspiron B130 Notebook
Ati2dvag.dll blue screen error and dont shut down the PC
It's a problem with the video driver, device driver. ATI
Here's the fix for the infinite loop problem caused by ati2dvag.dll that has worked for some others.
Right click on My Computer
Choose Properties
Choose the Hardware(Tab)
Choose Device Manager(button)
Click the [+] next to System devices
Right click on CPU to AGP Controller
Choose the Update Driver(button)
Select Install from a list or specific location (Advanced)
Choose Next(button)
Select "Don't search. I will choose the driver to install."
Choose Next(button)
Select PCI standard PCI-to-PCI bridge
Hit Next(button)
Hit Finish(button)
Reboot.
This should resolve your issue.
Jul 02, 2010 | Computers & Internet
My computer hangs every 10 - 20 minutes. My system configs are as follows: Asus M2N68-AM motherboard AMD Anthalon 6000+ DDRII 2GB
well try looking at your system fans if they are working correctly. then if they are, i think you have to reformat your pc.
Aug 02, 2009 | ASUS SOCKET AM2 AMD ATHLON 64 X2/64...
Installing a internet modem
you open case
have comp turned completly off
install ethernet card into proper slot screw down
turn on comp goto control panel network setup wizard follow instructions from there
remember first your modem has to be recognized by your service provider first before you can get that connection and they give you the service to connect
say like cox qwest or other service provider
May 09, 2008 | Dell Inspiron 5100 Notebook
I have an acer aspire 5315. i want to change my os from vista to xp, is this possible and how can i do it?
http://soulpass.com/2007/11/10/installing-windows-xp-professional-sp2-on-acer-aspire-5315-2153-laptop/
Looks like a nice tut to do it.
Apr 20, 2008 | Computers & Internet
On having to reload windows xp pro I found that I no longer had a working sound device. Is there a connection, should I try again or would this be caused be something else.
hello,
Maybe some make that caused, on destop of the "my computer" right click "properties" and then "hardware" tab and then" device manager"
see pic below:
tell me about error on your system.
melnavz
Apr 15, 2008 | Computers & Internet
To know my the free download software of my phone
For those who are having connection problem with moto
Step 1. Get the software
Go to Motodev and download Motorola USB Driver (you will need to register)
Also download your chosen p2k program e.g. p2kMan
It would also be a good idea to locate RSD Lite – you will have to use Google to find this as it is classed as warez and we cannot give
links.
Step 2. Install the driver program
Extract the file “Motorola_EU_Driver_Installation.msi” from the zip file you downloaded.
Double click on this file and the installation will start.
Click next and the EULA will appear
Click on "I Agree" (obviously having read the agreement first Angel), then next.
The program will now install
Click close to end the install procedure
During the installation process you may see the following screen 1 or
more times
Should this appear hit "Continue Anyway"
Step 3: Install the drivers
You will now have a new program group in your start>programs menu -"Motorola Driver Installer", with a shortcut called "Motorola Driver Installer.exe" within it.
Make sure the phone is disconnected at this time.
Run this program, and it will check whether the drivers are already
installed, when this is complete you will see the following screen
Under "Operation Mode" (lower left), select "Clean and Reinstall" (the bottom option).
Then hit "Start"
The program will then do its thing. When it is finished hit "Exit"
You may get the message about Windows Logo testing again - if you do hit "Continue Anyway"
Step 4: Connect the phone
Make sure the phone is turned on then connect the USB cable. It is best
to use a USB port on the rear of the PC rather than front mounted ports
as these sometimes connect to the motherboard via a hub
When you plug the phone in Windows will find new hardware - Motorola
Phone (V3), then Motorola USB Modem. The installation should
complete without intervention.
You should now be able to connect using Mobile Phone Tools, the phone
should also be charging.
We now want to install the P2k Drivers. First make sure MPT is not
running.
Now with the phone still connected run one of the P2k programs, I generally use P2kMan - but thats just me. Its best not to use p2k Tools as this may start in AT mode and confuse matters.
When you do this Windows should find several new devices and after a
short while the new hardware wizard will run. In the rare event the new
hardware wizard does not start, install and run RSD Lite.
The first screen to appear asks if you wish to connect to Windows Update
Select "No, not this time", then click on "Next"
Choose "Install the software automatically (Recommended)", then hit "Next"
The driver for Accessories Interface is then installed, after a short
while the following screen is displayed
Click "Finish"
The new hardware wizard will then run again
Once again select "No, not this time", then click on "Next"
This time the wizard asks for drivers for "Data Logging MCU Interface".
"Next"
Again the drivers are installed then after a short while the
following screen is displayed.
Click "Finish"
The new hardware wizard will then run for a third time
At the first screen select "No, not this time", then click on "Next" in the same way as before
This time the wizard asks for drivers for "Test Command Interface".
Again the drivers are installed then after a short while the following screen
is displayed.
Click "Finish"
Your P2k drivers are now installed and the P2k programs should
recognise the phone
Remember if you connect using a different USB port in the future,
Windows will recognise new hardware and you will need to repeat these
steps
Step 5: Flash Interface Device
If at anytime you choose to flash your phone you will need the Flash
Interface device installed. This device is used to communicate with the
phone while it is in bootloader mode.
In order to run the hardware installation wizard for this device you
can do one of two things. Either use RSD Lite to flash the phone as
normal (browse to the file and hit start) and RSD Lite will switch the
phone to bootloader mode for you. Alternatively you can start in
bootloader manually (hold * and # while turning the phone on), then
Either way the new hardware wizard will run again.
As before select "No, not this time", then click on "Next"
"Next"
is displayed.
Click "Finish" and you are done - you can now flash your phone with RSD
Lite.
Once more remember if you connect using a different USB port in the
future, Windows will recognise new hardware and you will need to repeat these steps
Nov 28, 2007 | Motorola Mobility RAZR V3
How to use buttons on Lexmark printer, plus having problems it tell me not connected .
Make sure that you have the Lexmark "All In One Center" installed - that's usually the problem when you get communication errors.
First, you'll need to install the software and driver for this printer:
  1. Make sure you have the regular printer driver installed. If you don't, you can grab it from the Lexmark website and install it.
  2. Next, keep your USB cords plugged in but turn your printer off.
  3. Download the All-In-One Center Software here.
  4. Unpack the archive, open the "Applications" folder, anddouble-click Setup. This will install the application - it can take abit.
  5. Once the application is installed, turn the printer on and try a test scan. If it works, you're good and can quit reading.
  6. If you get an error when running a test scan, don't panic.Reinstall the regular printer driver, using the "Update Driver" optionthat appears.
  7. Restart your computer.
  8. Do a new test scan. This should bring up the All In One Center'sloading screen, which will start searching for programs (this canreallllly take a while). When it's done, everything will be workingbeautifully again!
Then, hit Lexmark's site for the Setup Sheet and User Guide available here.
Oct 31, 2007 | Lexmark X1270 All-In-One InkJet Printer
Computers & Internet Logo
490 people viewed this question
David Payne
David Payne
